If you don't want to upgrade PBP, and you don't mind adding some additional code, here is a customizable I2C routine that will work with the DS1307 (it could also be set-up to work with multiple I2C devices):
' SDA = I2C serial data line
' SCL = I2C serial clock lines
DS1307 Con $D0                     ' I2C Slave Device "Write" Address (DS1307)
I2Cdelay con 15                    ' usec delay used in SDA and SCL timing
                                   ' routines.
blocksize con 8                    ' maximum # of bytes to send or receive
i2cBytes var byte                   ' # of bytes in data array
i2cData var byte[blocksize]         ' data array
i2cWork var byte                    ' work byte for TX routine
i2cDevAddr var byte                 ' Device Slave Address
i2cAddr var word                    ' Memory Address
i2cloop var byte
i2cindex var byte
' Subroutines
'DS1307 RTC Time/Date Register Block Write Routine
'(i2cData = data array, i2cbytes = # of bytes to send)
DS1307blkwrite:
    i2cDevAddr = DS1307                ' set slave device WRITE address
    Gosub I2C_AddrSend                 ' Send Address Info!
    For i2cindex = 0 To (i2cbytes-1)   ' loop for number of bytes in array
    i2cWork = i2cData[i2cindex]        ' xfer from array to temp
    Gosub I2C_TX_Byte                  ' Send Data!
    Next i2cindex
    Gosub I2C_Stop                     ' Finished!
'DS1307 RTC Time/Date Register Byte Write Routine
'(i2cData = byte to send, i2caddr = address of byte to write)
DS1307bytewrite:
    i2cWork = i2cData                  ' Transfer data!
'DS1307 RTC Time/Date Register Block Read Routine
'(i2cData = data array, i2cbytes = # of bytes to read)
DS1307blkread:
    Gosub I2C_Stop                     ' break between events and
    Gosub I2C_Start                    ' re-start for device read
    i2cWork = (DS1307+1)               ' set slave device READ address
    Gosub I2C_TX_Byte
    Gosub I2C_RX_Byte                  ' Receive Data!
    i2cData[i2cindex] = i2cWork        ' Transfer Data!
    If i2cindex != 6 Then Gosub I2C_ACK
    Next i2cindex
'DS1307 RTC Time/Date Register Byte Read Routine
'(i2cData = byte to receive, i2caddr = address of byte to read)
DS1307byteread:
    Gosub I2C_TX_Byte
    i2cData = i2cWork                  ' Transfer Data!
'I2C Device Read/Write and Memory Address Routine
'(i2cDevAddr = Device Address, i2caddr = Memory Address)
I2C_AddrSend:
    Gosub I2C_Stop                      ' Normalize Bus/Recover from errors
    Gosub I2C_Start                     ' send Start
    i2cWork = i2cDevAddr                ' send slave WRITE address
    Gosub I2C_TX_Byte
    i2cWork = i2caddr // 256            ' send LSB ADDRESS
    Gosub I2C_TX_Byte
    If i2cDevAddr = DS1307 Then Return  ' 1 byte memory address
    i2cWork = i2caddr / 256             ' send MSB ADDRESS
    Goto I2C_TX_Byte
' Low Level I2C Subroutines
' --- Start ---
I2C_Start:                          ' I2C start bit sequence
    Gosub SCLlo
    Gosub SDAhi
    Gosub SCLhi
    Gosub SDAlo                     ' SDA -> low while SCL high
    Goto SCLlo
' --- Stop ---
I2C_Stop:                            ' I2C stop bit sequence
    Gosub SCLlo
    Gosub SDAlo
    Gosub SCLhi
    Gosub SDAhi                      ' SDA --> high while SCL high
    Goto SCLlo
' --- Transmit ---
I2C_TX_Byte:
    For i2cloop = 0 to 7
    If i2cWork.7 = 0 Then
    Gosub SDAlo
    Else
    Gosub SDAhi
    Endif
    Gosub SCLhi
    Gosub SCLlo
    i2cWork = i2cWork << 1
    Next i2cloop
    Goto I2C_NACK
' --- Receive ---
I2C_RX_Byte:
    Gosub SCLhi
    i2cWork = (i2cWork*2)+ SDA       ' shift left and insert bit
    Gosub SCLlo
    Next i2cloop
'Get Acknowledge Bit
I2C_NACK:
    Gosub SDAhi
    Gosub SCLhi
    Goto SCLlo
'Send Acknowledge Bit
I2C_ACK:
    Gosub SDAlo
    Gosub SCLhi
    Gosub SCLlo
    Goto SDAhi
SDAhi:
    Input SDA
    Pauseus I2Cdelay
SDAlo:
    Low SDA
    Pauseus I2Cdelay
SCLhi:
    High SCL
    Pauseus I2Cdelay
SCLlo:
    Low SCL
    Pauseus I2Cdelay
There are 2 sets of routines, block read/write, and byte read/write.
Here is an example using block read to fetch the time/date registers:
'Retrieve RTC values
getclk:
    i2caddr = 0
    i2cbytes = 7
    Gosub DS1307blkread
    For indx = 0 to 6
    Select Case indx
    Case 0            'seconds
    secs = i2cData[indx]
    Case 1            'minutes
    mins = i2cData[indx]
    Case 2            'hours
    hours = i2cData[indx]
    Case 3            'day of the week
    dweek = i2cData[indx]
    Case 4            'day
    day = i2cData[indx]
    Case 5            'month
    month = i2cData[indx]
    Case 6            'year
    year = i2cData[indx]
    End Select
    Next indx
And here is a way to update those same registers with the block write routine:
'Update RTC registers from system variables
UpdateRTC:
    Gosub RTCoff
    For indx = 0 to 6
        Select Case indx
        Case 0            'seconds
        If newsecs = $FF Then newsecs = 59
        If newsecs > 59 Then newsecs = 0
        tTemp = newsecs
        Gosub dec2BCD
        Case 1            'minutes
        If newmins = $FF Then newmins = 59
        If newmins > 59 Then newmins = 0
        tTemp = newmins
        Gosub dec2BCD
        Case 2            'hours
        If newhours = $FF Then newhours = 23
        If newhours > 23 Then newhours = 0
        tTemp = newhours
        Gosub dec2BCD
        If newdweek = $FF Or newdweek = 0 Then newdweek = 7
        If newdweek > 7 Then newdweek = 1
        tTemp = newdweek
        Gosub dec2BCD
        Case 4            'day
        tTemp = month
        Gosub BCD2dec
        If tTemp // 2 = 0 Then
            daytop = 30
        Else
            daytop = 31
        Endif
        If tTemp = 2 Then
            tTemp = year
            Gosub BCD2dec
            If tTemp // 4 = 0 Then
                daytop = 29
            Else
                daytop = 28
            Endif
        Endif
        If newday = $FF Or newday = 0 Then newday = daytop
        If newday > daytop Then newday = 1
        tTemp = newday
        Gosub dec2BCD
        Case 5            'month
        If newmonth = $FF Or newmonth = 0 Then newmonth = 12
        If newmonth > 12 Then newmonth = 1
        tTemp = newmonth
        Gosub dec2BCD
        Case 6            'year
        If newyear = $FF Then newyear = 99
        If newyear > 99 Then newyear = 0
        tTemp = newyear
        Gosub dec2BCD
        End Select
    Next indx
    i2caddr = 0
    i2cbytes = 7
    Gosub DS1307blkwrite
    Goto RTCon
dec2BCD:
    tTemp = ((tTemp DIG 1) << 4) | (tTemp DIG 0)
    i2cData[indx] = tTemp
BCD2dec:
    tTemp = ((tTemp >> 4)*10) + (tTemp & %1111)
And here are some handy low level byte write routines:
RTCon:
    i2caddr = 0
    Gosub DS1307byteread
    If i2cData.7 = 0 Then Return
    i2cData = i2cData & %01111111
    i2caddr = 0
    Goto DS1307bytewrite
RTCoff:
    i2caddr = 0
    If i2cData.7 = 1 Then Return
    i2cData = i2cData | %10000000
    i2caddr = 0
RTChour24:
    i2caddr = 2
    If i2cData.6 = 0 Then Return
    i2cData = 0
    i2caddr = 2
And here is a routine that will do a block read and then update your system variables directly from the time/date registers:
'Refresh system variables from RTC registers
RTCrefresh:
    Gosub getclk
    tTemp = secs
    Gosub BCD2dec
    newsecs = tTemp
    tTemp = mins
    Gosub BCD2dec
    newmins = tTemp
    tTemp = hours
    Gosub BCD2dec
    newhours = tTemp
    tTemp = dweek
    Gosub BCD2dec
    newdweek = tTemp
    tTemp = day
    Gosub BCD2dec
    newday = tTemp
    tTemp = month
    Gosub BCD2dec
    newmonth = tTemp
    tTemp = year
    Gosub BCD2dec
    newyear = tTemp
I don't know if any of this will be of use to you, but I had it laying around and I figured I should at least offer it up.
