What is the resolution of the analog comparator of the 16F628A?
Results 1 to 2 of 2
    Dec 2006
    Brasil, Sao Paulo, Campinas
    Default What is the resolution of the analog comparator of the 16F628A?
    I would like to know the resolution the comparator channel. For example, using a PIC with A/D channel (10 bits) , the resolution is 4,88mV. I want to use a 16F628A, to compare 2 analog inputs. One with 3,100V and other with 3,115V for example...Is it possible or is necessary a minimal diference ?
    Sep 2009
    Default Re: What is the resolution of the analog comparator of the 16F628A?
    Resolution is infinite, or even bigger!
    There is no minimal difference, but you must count for input offset...
    It should be less then +-10mV(datasheet D300). You have 15mV, so not very good choose for your application.
  1. Replies: 2
    Last Post: - 31st May 2013, 18:19
  2. Comparator trouble with 16f628A
    By Davidmarks in forum mel PIC BASIC Pro
    Last Post: - 8th March 2011, 23:30
  3. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 09:38
  4. PULSIN Resolution
    By cotang in forum mel PIC BASIC Pro
    Last Post: - 28th December 2008, 21:47
  5. Replies: 4
    Last Post: - 5th October 2008, 09:11
