well i ended up changing all the posted code that needed the long varable to work out speed to Nbit math
it took some work time ,but the rewards are there in size of the reduced compile size - in my case i saved 8.5k over using longs
although i needed only 1 long varable - the speed value - selecting longs added 10.5k to compile size as soon as you tick the box , and that is a very big overhead when flash space is very tight
Nbit math has it high overheads as well - the include is compiled about 700bytes , but the real overhead is in having to use multi 32bit PRESISON varables( 4 were needed) to do the step by step math operations that can be avoided when using longs , as a result more ram space is used , and it is noticeably slower than using longs when showing the results, even when at 64Mhz.
Also having to do multi divides , the separate remainder value needs to be reincorporated into any following math which adds extra code and where possible should be avoided until you need the result reading back into PBP
anyone having to add longs , where only1 or 2 longs may be need should look at Nbit math as a possible alternative , more so when flash space is tight and longs are an expensive overhead in compile space.
cheers
Sheldon
