hi thanks for the input guys
to get it to do what i want i used longs ;(
which i would like to change to 2 x word variables for this one long variable "Event_Dist_Speed "
i thinking perhaps the nbit math may work but not sure how it may be done with the calculations i have now
Code:' routine to calc speed based on sec under 18 hours Distance_Calc_Speed0: if Event_Dist_Timebase = 0 then Event_Dist_Speed = Event_Dist_Value ' calculate speed with base in secs if Event_Dist_Timebase = 1 then Event_Dist_Speed = Event_Dist_Value*60 ' calculate speed with base in mins Event_Dist_Speed = Event_Dist_Speed*100/(EL1_Seconds + (EL1_Minutes + EL1_Hours*60)*60) if Event_Dist_Timebase = 2 then gosub Distance_Speed_Calc2 ' calculate speed with base in hours - gosub becuase it is called as a seprate display ' HSEROUT [" Event_Dist_Speed = ",dec Event_Dist_Speed, 10,13] ' debug return ' ---------------------------------------------------------------- ' routine to calc speed based on sec 's ' used when time is >18 hours so that value is < word max size Distance_Calc_Speed1: return ' ------------------------------------------------------------------ ' show KPH or MPH on every base reading formular ' calculate speed with hours base ' called as 2nd speed display details Distance_Speed_Calc2: Event_Dist_Speed = Event_Dist_Value*360 if Event_Dist_Measure = 0 then Event_Dist_Speed = (Event_Dist_Speed*1000/5280)/(EL1_Seconds + (EL1_Minutes + EL1_Hours*60)*60) ' if feet distance base if Event_Dist_Measure = 1 then Event_Dist_Speed = Event_Dist_Speed*100 /(EL1_Seconds + (EL1_Minutes + EL1_Hours*60)*60)/100 ' if meters distance base if Event_Dist_Measure > 1 then Event_Dist_Speed = Event_Dist_Speed*1000 /(EL1_Seconds + (EL1_Minutes + EL1_Hours*60)*60) ' if Miles or KM distance base ' HSEROUT [" hour reading Event_Dist_Speed = ",dec Event_Dist_Speed ,10,13] ' debug return '------------------------------------------------------------------ Show_Speed_Value: gl_x = 0 gl_y = 48 gl_k = 0 for gl_k = 0 to 7 lookup gl_k,[" x.xx"],Sml_font ' 8 chrs gosub Get_Sml_font ' Get Font in K9_Fonts_banners.bas gl_x = gl_x+8 next gl_k gl_x = 0 ' puts 5 digits of speed 00000.xx g_num = Event_Dist_Speed /100 ' get the base value 00000.xx gosub Sml_put_5dig gl_x = 48 ' put first 2 digits of speed xxxxx.00 g_num = Event_Dist_Speed gosub Sml_put_2dig return
