some help with math
Results 1 to 40 of 65
    Aug 2003
    Default Re: some help with math
    If you have to check for <3 as well you might be approaching the code size of the lookup table.
    Are all the lookup tables repeating like this? It’s the sort of problem I like,
    certianly a mind F* though.
    Feb 2012
    PERTH AUSTRALIA
    as a test i reversed high to low byte in the font structure
    unfortunately it worked , and this is supported by the data dumps as shown in previous posts , so to make the font common routine work i would have to reverse all the data stucture for each font chr - which if i dont have abetter option will need to be done
            ' Code for "0"  Asci 48    90 real values _
    @ dw      0x0000,0x0000,0x00FF,0xFF03,0x0FC0,0xF0FF,0xFF1F,0x1FF8,0xF8FF,0xC33F,0x3FFC,0xFC81;,0x3F
    @ dw      0x813F,0x7FFC,0xFE00,0x007F,0x7FFE,0xFE00,0x007F,0x7FFE,0xFE00,0x007F,0x7FFE,0xFE00,0x007F   ;swaped low high bytes arround
    @ dw      0x7FFE,0xFE00,0x007F,0x7FFE,0xFE00,0x813F,0x3FFC,0xFC81,0xC33F,0x1FFC,0xF8FF,0xFF1F;,0xF8
    @ dw      0x0FF8,0xF0FF,0xFF03,0x00C0,0x00FF,0x0000,0x0000,0x0000
    Aug 2003
    If you can write to that area your program could swap the data and write it back,
    then set a flag somewhere in a spare EEPROM bit to flag not to do it again.
    That’s if you can’t write something to spit it out a serial terminal in the format you want it.
    If the pic can read that and also has a serial terminal, you should be able to get it to format the lines as code you have above.
  1. Help with A/D math!
    By dbodenheimer in forum mel PIC BASIC Pro
    Last Post: - 19th March 2011, 00:51
  2. Math help please...
    By Ioannis in forum General
    Last Post: - 20th June 2008, 10:18
  3. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 10:22
  4. Math help please!!!
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 14:45
  5. math help
    By houa in forum mel PIC BASIC Pro
    Last Post: - 30th January 2006, 16:58
