well i been going though my code and i had about 35 lookup tables in various values and size , most have been changed now to math calculation , most were of simular in how they need to place font, chrs , on a glcd within menus
the goal is to reduce code size as lookups really do chew up space
this along with change any IF /then to a math caclulation where possible
removing any multi if /then when used to compare to for/next loop compare
moving bit varables into the same byte to use bit matching on them
remove any "and " in if/then and just doing 2 if/then statements - this often saved about 50 bytes each
moving any lookup "txt into spi flash so it not on the main cpu flash
all these saved so far a total of 33k from a code that started at 127k
still trying more space as i really would like to get to 90k code before i add the next section
found pokecode has a limit of 256 bytes before for adata string ,
and this i cant find a better way to do to reduce its compile size
   if val < 6 AND Menu_Select = 211 then
            lookup val,[1,2,4,8,16,32],val      '  reasign  val to
            gosub Show_current_sel_2            ' place "*    *" on the selected channel in menu using bit pattern sleection
         if val =>6  and val <= 11 and Menu_Select = 2112 then
            lookup val-6,[1,2,4,8,16,32],val
         if val =>12 and Menu_Select = 2113 then
            lookup val-12,[1,2,4,8,16,32],val
i am also ll stuck with a lot of if then statements when input range checks are done when a key is pressed such as
and i cant see away to reduce them
 Input_Timevalue_Check:
  ' input checks for time inputs from menu1111
    if Event1_OT_Day >7 then
       Event1_OT_Day     = 0
       Event1_OT_hour    = 0
       Event1_OT_Min     = 0
       Event1_OT_sec     = 0
       Event1_OT_100th   = 0
    if Countdwn_Day > 7 then
       Countdwn_Day      = 0   ' day settings
       Countdwn_Hour     = 0
       Countdwn_Min      = 0
       Countdwn_Sec      = 0
       Countdwn_100th    = 0
    if Event_Penalty_Day >7 then
       Event_Penalty_Day   = 0
       Event_Penalty_Hour  = 0
       Event_Penalty_Min   = 0
       Event_Penalty_Sec   = 0
       Event_Penalty_100th = 0
    if Event2_OT_Day >7  then
       Event2_OT_Day     = 0
       Event2_OT_hour    = 0
       Event2_OT_Min     = 0
       Event2_OT_sec     = 0
       Event2_OT_100th   = 0
    if Preset_EL0_Day >7 then
       Preset_EL0_Day    = 0
       Preset_EL0_Hour   = 0
       Preset_EL0_Min    = 0
       Preset_EL0_Sec    = 0
       Preset_EL0_100th  = 0
    if Event1_OT_Hour >23      then Event1_OT_Hour     = 23
    if Countdwn_Hour  >23      then Countdwn_Hour      = 23
    if Event_Penalty_Hour > 23 then Event_Penalty_Hour = 23
    if Event2_OT_Hour > 23     then Event2_OT_Hour     = 23
    if Preset_EL0_Hour > 23    then Preset_EL0_Hour    = 23
    if Event1_OT_Hour <1       then Event1_OT_Hour     = 0
    if Countdwn_Hour  <1       then Countdwn_Hour      = 0
    if Event_Penalty_Hour <1   then Event_Penalty_Hour = 0
    if Event2_OT_Hour  <1      then Event2_OT_Hour     = 0
    if Preset_EL0_Hour <1      then Preset_EL0_Hour    = 0
    if Event1_OT_Min >59       then Event1_OT_Min     = 59
    if Countdwn_Min > 59       then Countdwn_Min      = 59
    if Event_Penalty_Min > 59  then Event_Penalty_Min = 59
    if Event2_OT_Min >59       then Event2_OT_Min     = 59
    if Preset_EL0_Min >59      then Preset_EL0_Min    = 59
    if Event1_OT_Min <1        then Event1_OT_Min     = 0
    if Countdwn_Min <1         then Countdwn_Min      = 0
    if Event_Penalty_Min <1    then Event_Penalty_Min = 0
    if Event2_OT_Min <1        then Event2_OT_Min     = 0
    if Preset_EL0_Min <1       then Preset_EL0_Min    = 0
    if Event1_OT_Sec >59       then Event1_OT_Sec     = 59
    if Countdwn_Sec >59        then Countdwn_Sec      = 59
    if Event_Penalty_Sec >59   then Event_Penalty_Sec = 59
    if Event2_OT_Sec > 59      then Event2_OT_Sec     = 59
    if Preset_EL0_Sec > 59     then Preset_EL0_Sec    = 59
    if Event1_OT_Sec <1        then Event1_OT_Sec     = 0
    if Countdwn_Sec <1         then Countdwn_Sec      = 0
    if Event_Penalty_Sec <1    then Event_Penalty_Sec = 0
    if Event2_OT_Sec <1        then Event2_OT_Sec     = 0
    if Preset_EL0_Sec <1       then Preset_EL0_Sec    = 0
    if Event1_OT_100th > 99    then Event1_OT_100th     = 99
    if Countdwn_100th > 99     then Countdwn_100th      = 99
    if Event_Penalty_100th >99 then Event_Penalty_100th = 99
    if Event2_OT_100th > 99    then Event2_OT_100th     = 99
    if Preset_EL0_100th > 99   then Preset_EL0_100th    = 99
    if Event1_OT_100th <1      then Event1_OT_100th     = 0
    if Countdwn_100th <1       then Countdwn_100th      = 0
    if Event_Penalty_100th <1  then Event_Penalty_100th = 0
    if Event2_OT_100th <1      then Event2_OT_100th     = 0
    if Preset_EL0_100th <1     then Preset_EL0_100th    = 0
