Data conversions
Results 1 to 7 of 7
    Aug 2015
    Default Data conversions
    Wanted to do a temp probe using the 1822 but then got into a situation. The sample code provided to me does an Lcdout command with a dec(temperature) to display. According to the manual this is a decimal conversion from ascii. Then I wanted to be able to store data. Up to here I was ok. Write to eeprom. But I decided to use a serout command instead of LCDout which totally barfed when I tried to compile. I have tried to convert the data into something more friendly like a standard string but am unable to come up with any solution. Yes, I can just use the lcdout command but now it's turned into a challenge/learning experience. Any one have an idea of how to start to convert this into a standard string or how to get this to use the serout command? Even if it's not practical to program into the chip I'm interested from a learning perspective now.
    Thanks much
    SerPin VAR PortA.0 ' Serial output pin
    temperature     VAR     WORD            ' Temperature storage
    count_remain    VAR     BYTE            ' Count remaining
    count_per_c     VAR     BYTE            ' Count per degree C
    DQ      VAR     PORTC.0                 ' One-wire data pin
    DEFINE  LCD_DREG        PORTD
    DEFINE  LCD_DBIT        4
    DEFINE  LCD_RSREG       PORTE
    DEFINE  LCD_RSBIT       0
    DEFINE  LCD_EREG        PORTE
    DEFINE  LCD_EBIT        1
    AA var byte
    BB var byte
    CC var byte
    DD var byte
            ADCON1 = %00000111              ' Set PORTA and PORTE to digital
            Low PORTE.2                     ' LCD R/W line low (W)
    mainloop:
            OWOUT DQ, 1, [$CC, $44] ' Start temperature conversion
            pause 2000
            OWOUT DQ, 1, [$CC, $BE]         ' Read the temperature
            OWIN DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE]
            ' Calculate temperature in degrees C to 2 decimal places
            ' (not valid for negative temperature)
            temperature = temperature */ 1600
            LCDOUT $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " C"
            ' Calculate temperature in degrees F to 2 decimal places
            temperature = (temperature */ 461) + 3200
            LCDOUT $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " F"
    serout serpin,N9600,{(temperature/100)] 'won't even compile
    GoTo mainloop                   ' Do it forever
    Default Re: Data conversions
    syntax error
    check your serout line
    Aug 2015
    Wow, that sure makes me feel like a drone, I looked at that a hundred times.
    Aug 2015
    Ok, so that makes it compile but all I get is garbage out. The data is not compatible to that command so I still need to convert the data.
    Anyone have any ideas?
    Well, provided you've got baudrate, voltage levels and polarity all correct it looks like what's missing is the DEC modifier in serout command. Without the dEC modifier you're sending the data "as is" and not as ASCII text that you can read on a terminal.
    serout serpin,N9600,[DEC (temperature/100)]
    Aug 2015
    Yes, that's true, but if you add dec to the serout command it doesn't compile
    serout2 serpin,N9600,[DEC (temperature/100)] if possible
    or
    serout serpin,N9600,[#(temperature/100)]
    or
    might need to be
    temp=temperature/100
    serout serpin,N9600,[#temp]
  1. linear data memory & large data arrays
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 27th June 2011, 23:21
  2. storing data and dumping data?
    Last Post: - 28th November 2007, 15:57
  3. Help with Data of fiberoptic
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 29th June 2007, 14:23
  4. Data
    By gzorzi in forum mel PIC BASIC Pro
    Last Post: - 16th July 2004, 14:21
  5. ADC Conversions
    By Corey in forum mel PIC BASIC Pro
    Last Post: - 7th October 2003, 04:32
