frequency meter output
Results 1 to 4 of 4
    Jun 2008
    Varese , Italy
    Default frequency meter output
    Good day to all of you in the forum.
    I have seen a lot of projects on the web relevant to the frequency meter using PIC's. All of them send the measured frequency on an LCD.
    I am asking if somebody knows a freq meter project in which the measured frequency is sent over the serial output.
    Thanks for helping.
    regards,
    Ambrogio
    Aug 2003
    Default Re: frequency meter output
    Take any of those projects where the source is given up for a micro platform,
    after the sample period, at the time of printing to the display, also send the value to a hardware serial port.
    If the value is higher than a byte, fill a buffer and empty a byte at a time, and rewrite the buffer for every cycle it’s emptied.
    That kind of serial frequency counter would be as accurate as any other for the period measured,
    but if you were watching a frequency that changed fast, that chip can’t track it with much speed. It would be a horrible spectrum analyser
    Jun 2008
    Varese , Italy
    Thanks Art,
    have you some sample source program to suggest please ?
    regards,
    Ambrogio
    Serial output, as you mentioned: http://www.moty22.co.uk/c1mhz.php
    Even better, USB output: http://www.moty22.co.uk/usb_counter.php
    Anand
  1. LC meter,frequency meter
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 14th July 2011, 21:20
  2. PULSIN for frequency meter?
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 11th November 2008, 14:07
  3. need help-frequency meter 50mhz
    By vu2iia in forum General
    Last Post: - 9th December 2007, 17:50
  4. frequency meter in PBP
    Last Post: - 13th June 2007, 07:34
  5. frequency meter from 16f84a to 16f88
    Last Post: - 4th November 2006, 14:28
