Thank you Art, but rotatearray is not working for me.
To simplify the question, I used text on the left side as: V1, V2, V3 but actually they are different strings, that is what creates the problem.
1.MY FIRST VARIABLE=20
2.SECOND VALUE =25
3.THIRD ONE =30
4.DIFFERENT >40
5.FIFTH VAR =50
6.SIXTH VAR =60
Since I can only show 4 lines on the LCD, when the user presses DOWN button I need to know the following:
selected_variable: Which variable is the user currently on (in the above example: 4)
first_line_displayed: Which lines should be displayed OR which line should be on the top (in the above example: 2)
Here is a table I created:
Dark grey is the currently selected variable
Light grey are displayed in the LCD
Based on this table:
first_line_displayed = selected_variable - 2
IF (selected_variable - 2 <= 0) THEN first_line_displayed = 1
IF (selected_variable = max_number_of_variables) THEN first_line_displayed = selected_variable - 3
This very simple method works for display purposes. However, the problem is I cannot form a loop to go through all 8 (or less/more) variables and display only the ones that should be played based on the table above (and on the correct place). Can you help me form such a loop?
