Making Code Smaller for a Multiplexed LCD Display
Results 1 to 12 of 12
    Default Re: Making Code Smaller for a Multiplexed LCD Display
    Hello
    Which pic are you using? There are some newer chips like the 16f1939 with 1k ram and 16K of program space. There are 18f with double.
    Miami, Florida USA
    Quote Originally Posted by mark_s View Post
    Hello
    Actually, I'm using the 16F1939. I'm going to check for the 18F that you mentioned.
    Anonymous
    Aug 2003
    I think it’s tough, but a curiosity now,
        LCDDATA11.1 = PATTERN.7
    How did you define these?
    Is PATTERN a single byte you are looking at bits 0-7,
    and LCDDATA, there are 11 bytes, and you look at bits 0-7 of all 11 bytes?
    I’ve not used that syntax before, but PATTERN.bit7 (to address a bit), or PATTERN[7] (to address a byte).
    Miami, Florida USA
    Art, in this example there is a multiplexed 7-segment LCD, 4 commons, display that I am running directly from the PIC. The advantage of the 4 commons is that you only need one pin in the PIC for every 4 segments of the display, so you minimize the number of needed pins.
    The byte PATTERN changes its value for everyone of the 8 digits of the display. After enabling the LCD feature in the PIC, you need to load LCDDATA the registers for it to work.
    Anonymous
  1. LCD display without firmware, problem with code
    By tomadarpel in forum mel PIC BASIC
    Last Post: - 30th May 2013, 12:20
  2. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 14:28
  3. Trying to make code smaller
    By plyrathrt in forum mel PIC BASIC Pro
    Last Post: - 5th January 2009, 18:20
  4. Making PBP code more modular
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
