Making Code Smaller for a Multiplexed LCD Display
Results 1 to 12 of 12
    Miami, Florida USA
    Default Re: Making Code Smaller for a Multiplexed LCD Display
    Is this display a 7 segment?
    Yes, it is.
    Anonymous
    rsocor01, This may be a starting point:
    EN82fn
    Bombay, India
    Actually, I have run into a similar LCD design very recently and have to eventually work on it. What he has is a segmented LCD glass with a controller. The various segments are scattered around the face of the lcd and not similar to a 7 segment LEDs grouping. Look carefully and you will find bits of each pattern are scattered around the lcddata bytes. To my mind, what rsocor01 has got now seems suitable if not ideal.
    Miami, Florida USA
    Dave,
    This LCD is actually a 7-segments, 4 commons, multiplexed display. That code is more for an LED display type.
    Jerson,
    Thanks for your comment. So, you know that this displays are a pain in the neck to work with . The code that I posted works perfectly fine, and it can serve as a reference for somebody working with these displays in the future. However, it takes a lot of code space. I was hoping PBP could do something like
    DIGIT_0.0   VAR   LCDDATA0.7
    DIGIT_0.1   VAR   LCDDATA3.7
    DIGIT_0.2   VAR   LCDDATA6.7
    ......... And so on
    But, I don't think that it can do it. Any ideas?
    Anonymous
    Bombay, India
    Even if it could, the underlying code will still have to do the same hard work of juggling bits around. So, eventually, there may only be syntactic sugar, but the bitterness will remain(code size).
    Miami, Florida USA
    Yeap, you are right. I was hoping that somebody knew of a clever way of doing this.
    Anonymous
    Hello
    Which pic are you using? There are some newer chips like the 16f1939 with 1k ram and 16K of program space. There are 18f with double.
  1. LCD display without firmware, problem with code
    By tomadarpel in forum mel PIC BASIC
    Last Post: - 30th May 2013, 12:20
  2. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 14:28
  3. Trying to make code smaller
    By plyrathrt in forum mel PIC BASIC Pro
    Last Post: - 5th January 2009, 18:20
  4. Making PBP code more modular
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
