Dodge temp sensor
Results 1 to 8 of 8
    Aug 2003
    Default Dodge temp sensor
    Hi Guys,
    I’m looking for a cheap dodge of hardware temperature sensor by using an RC clock variation
    to detect temperature variation where the supply voltage to the pic is precise,
    but the temperature reading does not have to be precise.
    I know this is possible with the watchdog timer, but that has to be allowed to reset the program,
    and could only be practically used for measurement once at the start of a program.
    Is there another RC clock I’d have access to in the same manner?
    Otherwise an external RC circuit should work... I just pick the clumsiest components that will vary with temperature
    Cheers, Art.
    Default Re: Dodge temp sensor
    Hi
    Before integrated temperature sensors were introduced. Designers used forward biased
    diodes and measured the voltage drop with temperature change. This was good enough for
    HVAC system thermostats. The RC method would probably drive you crazy.
    http://automationwiki.com/index.php/...rature_Sensors
    Aug 2008
    Portugal
    Quote Originally Posted by mark_s View Post
    Hi
    Hi would do it with a 1N4148. Works good for this aproach!
    Thanks and Regards;
    Gadelhas
    Feb 2012
    PERTH AUSTRALIA
    not heard of this with the IN4148 method , how close to the temp source would the diode need to be , get any real temp variation ?
    Quote Originally Posted by longpole001 View Post
    Just like any thermometer or sensor. It will measure the ambient temperature. If you wanted to monitor a power transistor it would have to make contact or be very close. Best way to see it in action is solder a 4.7k in series with a 1N4148, 1N914 or a 1N4001 connect it to 5 volts and measure the voltage across the diode. You can see the voltage change by pinching the diode or take a fan cool it down. The draw back to the diode method, is the voltage change is not linear. It was common to use a look up table to correct the non linearity. I don't remember how it was calculated, should be easy to find?
    Aug 2003
    It sound like a good approach.. I haven’t heard of it.
    I don’t mind using a lookup table of three bytes
    Basically I only want a rough range: Cool, Warm, Hot.
    So I would only need a few constant values to compare.
    Hi, Art
    @ first you simply can use the PBP RCTime function ... or place a NTC as R for the main OSC and comparing an external RC circuit time constant to a fixed soft Delay ( PAUSE i.e. ) that, here, will change with temp ...
    Aug 2003
    Yes, I was also thinking the POT command which would be similar.
    Digital measure of capacitor discharge through a resistor.
    The resistor there could be a thermistor and quality capacitor if it mattered a lot.
    I want to come up with a good method of watching other chips in a circuit,
    or just one sensor if the thing is in an enclosure, just because it can be cheap so one might as well use any spare pins.
    For now, I like the idea of just looking at a startup temp, a normal operating temp,
    and a severe warning temp hotter than expected where action might be taken to turn off a power transistor.
  1. TMP05 Temp Sensor
    By RichG in forum mel PIC BASIC Pro
    Last Post: - 8th February 2009, 03:33
  2. TCN75 Temp Sensor
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2008, 20:37
  3. Using WDT as a Temp Sensor?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 20th June 2006, 17:55
  4. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 15:55
  5. 1 wire Temp sensor
    By PortlandJohn in forum General
    Last Post: - 25th November 2005, 16:21
