12F1840 ADCIN troubles, help needed :(
Results 1 to 22 of 22
    Default Re: 12F1840 ADCIN troubles, help needed :(
    Thanks, but that is a bit complicated - no need to save that much power. The battery voltage to be monitored is around 11V (3S LiPo), so divider with 470k/100k resistors should work just fine?
    Sep 2009
    Look at last post.
    Tried that already. Too small values and I have too large ripple going on (current consumption is 20-25A). So I settled with 750k/150k+1nf combo, works just fine.
  1. 12F1840 config issues
    By enigma in forum PBP3
    Last Post: - 15th February 2015, 08:49
  2. Problem converting 12F683 code to 12F1840
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th March 2013, 02:55
  3. Help needed with ADCIN Averaging Routine
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 24th December 2012, 17:05
  4. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 09:32
  5. troubles using more than one PCF8574
    By maus in forum mel PIC BASIC Pro
    Last Post: - 28th July 2007, 20:37
