Question about flow sensor
Results 1 to 5 of 5
    Default Question about flow sensor
    I am looking at this flow sensor for one application: http://www.farnell.com/datasheets/81401.pdf
    I have never used one before so I have a basic question about this model. It is about the flow rate which is mentioned at 0.5L/min. Does it mean that, this should be the maximum flow which should pass through it? What happens if flow is more than this, like 3L/min, will it break it?
    ___________________
    WHY things get boring when they work just fine?
    Oct 2009
    Utah, USA
    Default Re: Question about flow sensor
    There is a graph on the second page that shows pressure drop vs. flow and it seems to indicate that the device is capable of handling upwards of 14 lpm.
    I would think that .5 lpm may be the minimum flow that it can accurately detect.
    I've never used one of these before but that seems reasonable to me.
    good luck
    Dwight
    Oct 2009
    Utah, USA
    Actually after taking a second look at the sheet and the title of "Flow Switch" it seems to me that it is only going to give you an indication that there is flow. Not the magnitude of that flow. you will likely only get a 1 or a 0 for Flow / No Flow indication. And it will only indicate flow if it is over .5 LPM.
    but I could be wrong
    Were you wanting something to indicate quantity of flow??
    If so, you may need to look elsewhere.
    Dwight
    Operating Pressure: 10BAR
    as long as this pressure is not exceeded the sensor will be ok , it may not reliably be able to accurately measure the actual flow rate below the 0.5/lpm rate however
    Heckler is right. It is nothing more than a flow switch. It gives an indication of flow greater than .5L/min. by moving a magnet attached to a pivoted plate upstream from the flow. As the flow increases, it pushes the plate out of the way towards a magnetic read switch. There are various other types of FLOW METER designs such as: Turbine, Positive displacement piston, Optical ball and circular tube, Rotary vane, Ultrasonic, Diferential Pitot tube, just to name a few.
    EN82fn
  1. Guide on flow sensor application
    By tacbanon in forum FAQ - Frequently Asked Questions
    Last Post: - 11th March 2013, 08:16
  2. Temp & Humidity sensor interfacing question
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 20th February 2012, 23:12
  3. fuel flow sensor?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 20th May 2009, 04:01
  4. Mass Air Flow Sensor Data
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 1st January 2009, 09:35
  5. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 04:05
