Whenever you GOSUB somewhere the adress after from where you GOUSBed is pushed onto the stack (stored in memory). If another GOSUB is executed the adress after THAT gosub is pushed onto the stack and the first adress stored is "pushed down". When a RETURN is executed the adress at the top of the stack is popped (retreived) and the execution jumps to that adress. This is how it works in any language, not just PBP.
If you GOSUB somewhere you must go back with a RETURN.
You can not RETURN from somwhere to where you did not GOSUB.
This too is NOT unique to PBP.
Now, it's perfectly fine to use GOTO from a subroutine to which you jumped with a GOSUB as long as you eventually end up at a "matching" RETURN. Example:In the above example the RETURN instryction at the end of DoThis and DoThat "matches" the GOSUB in the Main loop, Everything is fine. However, if you in somewhere in the main loop (or whatever) did a GOTO DoThat things would go bad because there's a "non matching" RETURN at the end. When the execution hits that RETURN it will pop "something" of off the stack and go there - not what you want.Code:Main: Toggle PortB.0 Pause 100 GOSUB CheckSwitch Goto Main CheckSwitch: If PortA.0 = 1 THEN GOTO DoThis ELSE GOTO DoThat ENDIF RETURN DoThis: ' Whatever RETURN DoThat: ' Whatever RETURN
Again, this is NOT unique to PBP in any way.
