Variable voltage output from a Pic?
Results 1 to 9 of 9
    Jul 2004
    Smile Pwm
    Hi Guys, thanks for your thoughts on this.
    What i'm trying to do is control the colour of a tri-colour LED (red, green and blue) I want to be able to set the overall colour of my LED at any colour using different voltages on each pin.
    I wasn't aware of the PWM command until now, it works well but goes low when I come out of the PWM loop.
    In my code, i'm using the SerIn command to listen for the RGB values, set the colour of the LED acordingly and then wait for another input.
    The hardware HPWM command sounds perfect, that way I can just alter the colour and go back to SerIn.
    My other problem is that I have 100x tri-colour leds to control. It shouldn't be too much of a problem to address them all, thats if the 16F628 supports SerIn?
    I don't mind having 30 of these pics (10 for each colour), each controling 1 colour of 10 separate led's. Do you know if there are enough outputs on the 16F628 to do this?
    Many Thanks,
    Dan
    mytekcontrols's Avatar
    mytekcontrols Guest
    Dan,
    Bad news on the hardware PWM. The 16F628 only has one port with this feature. There are other chips that have more, but off the top of my head I do believe the maximum is 4 PWM ports.
    PWM is definately a good way to go, in fact since I now know you'll be controlling LEDs, you don't need to convert this to analog (controlling the duty cycle should be sufficient). The 16F628 has 16 I/O ports available, but like I said only one of them supports the HPWM function. Perhaps you can do it as a software PWM, but not via PBP's PWM command. Instead do it with a bit of embedded ASM code. Check out this link: http://www.dattalo.com/technical/software/pic/pwm8.asm
    It describes a method of producing 8 PWM outputs. If you used this with a PIC chip that has a built-in USART, you should be able to do what you have in mind, and not use too many pic chips (perhaps extend it to 10 PWM outputs).
    Better still, would be if the software PWM was done as an interrupt service routine. This would allow you to write everything else in PBP, but still have stable PWM pulses. If I come across a good way to do this I'll post it here.
    Timer interrupt is also a way to go and do PWM on multipl output... much trickier but not impossible..
    Another Idea is to use Multiples DAC like MAX517/518 on few I2C BUS.
    Mentor, Ohio
    Hello,
    From the picture you provided and the description of your project it looks like each color has it's own pin plus a common for all 3 colors. Why then would you need PWM? It would seem like you only need an "ON" or "OFF" for each color which then is 1 pin per color which would then mean 5 LEDs per PIC.
    Let me know if I'm off base here but after reading the above posts that's the way I interpret what you want to do.
    BOBK
    Feb 2004
    Germany
    Quote Originally Posted by BobK
    ...It would seem like you only need an "ON" or "OFF" for each color which then is 1 pin per color which would then mean 5 LEDs per PIC.
    BOBK
    Bob,
    that way you would only be able to produce 7 different colors.
    If you want the full spectrum you have to control the intensity of every base color individually.
    regards
    Ralph
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  2. Replies: 5
    Last Post: - 30th April 2008, 20:01
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
  5. can a pic remember a variable?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2005, 09:50
