You're giving up to easily.... I don't have a 16F1827 but I have a 16F1825 which also have the temp indicator module. If you can't get it going I will bread-board it and give it a go but I have my own Projects as well and I'd rather work on those at the moment :-)
One thing I see when Reading the datasheet is this:You have set an acqusition time of 20us, 10 times less than what's required. Try DEFINE ADC_SAMPLEUS 200 and see what happens.To ensure accurate temperature measurements, the
user must wait at least 200us after the ADC input
multiplexer is connected to the temperature indicator
output before the conversion is performed. In addition,
the user must wait 200us between sequential
conversions of the temperature indicator output.
I'll let you know what I get after I try what you suggest ...
