Temperature Indicator Usage
Results 1 to 14 of 14
    Default Re: Temperature Indicator Usage
    Hi
    had a quick at the datasheet, looks like an interseting device. But did you see the errata, oh dear.
    You certainly need to set ADCON0 = x11101xx (x - not relevant) Fig16.1 "Temp indicator" input to ADC multiplexor
    You need to turn on TSEN (which you have done)
    And as the datasheet says
    The temperature sense circuit is integrated with the Fixed Voltage Reference (FVR) module
    maybe you need to turn that on as well,
    so FVRCON = 1x1xxxxx
    George
    Jan 2013
    Texas USA
    Also the DS refers to a separate Application Note regarding this. AN1333
    TABSoft
    Dec 2012
    Türkiye
    Quote Originally Posted by Tabsoft View Post
    The application note is but a general calibration and formulation for pic families that posses such a function , there is no information in that A.N. regarding configuration of the module ...
    - Ipsa scientia potestas est -
    Dec 2012
    Türkiye
    Quote Originally Posted by towlerg View Post
    I've seen the published ERRATA for 1827 thus the missing TSEN - TSRNG bits in the original datasheet yet what you suggest with the sentence that starts with "certainly" is completely wrong .. Is it not the point why we use a compiler language that connects the holding capacitor to the "Analog Channel " / and the automatic control of the GO/DONE bit and those all other things that is required for a proper operation of an ADC conversion in a single line with single command for us ? AKA ADCIN? As you may know the usage of the ADCIN command we have to first select a channel and state a variable for the incoming result to be stored , in this manner which is the channel 29 which I've already put in the code .. Configuring the ADCON0 CHS<4:0>bits doesn't do any favor to us except stalling the MCU for one more instruction cycle ..
    Second of all about your idea of setting the FVRCON.7 enable bit doesn't make any sense , If you've observed the original datasheet page 137 the temperature indicator module's positive power supply can not be chosen and uses the VDD directly ...
    But thanks for your approaches anyway ...
    Sorry, I've read this twice and I still don't understand. The multiplexer feeds the ADC with which ever input you select. You use ADCON0 to select the required input to the multiplexor.
    My suggestion that the FVR module may need to be enabled has nothing to do with Vdd - the manual states that the temperature indicator is part of the FVR module and FVREN controls the FVR module (FVREN is FVRCON.7)
    Sadly, I think this is ultimately a waste of time, without 2 point calibration the indicated temperature is "all over the place" and really only suitable as an overheat warning - just my 2 cents.
    George
    Dec 2012
    Türkiye
    Sorry, I've read this twice and I still don't understand. George
    What you do by configuring the ADCON0 CHS<4:0> bits is already done by the number written in bold format ---> ADCIN 29,VAR [29 refers to Temperature Indicator Already]
    According to your claim : Each time you would like to get an ADC operation on different channels you first have to change the ADCON0 ? The answer is A NO ..
    Because the PicBasic command does it for us ...
    Have you seen anything associated in the diagram below that has anything to do with the configuration of the module except TSEN - TSRNG bits ? If there was there would be other registers shown out there ...
    I don't think it is a waste of time at all and that's why I'm craving to solve this issue ...
    Aw well, each to his own.
    George
    Dec 2012
    Türkiye
    Anyone has an idea ?
  1. One of 33 LED output Indicator
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 5th December 2012, 18:26
  2. About the replacement of the indicator with BASIC.
    By apollo21 in forum mel PIC BASIC Pro
    Last Post: - 8th June 2008, 05:56
  3. Interrupt usage
    Last Post: - 20th April 2008, 17:20
  4. Serin usage?
    By champion in forum mel PIC BASIC Pro
    Last Post: - 24th January 2007, 01:57
  5. Temp. Indicator.
    By PIC Coder in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 07:10
