Simple question about While Wend...
Results 1 to 10 of 10
    Jan 2013
    Texas USA
    Default Re: Simple question about While Wend...
    What PIC MCU are you using?
    Should you be using LATB register instead of PORTB register for your High and Low statements?
    Read modify write may be an issue.
    TABSoft
    Oct 2008
    I am using an 18f2550.....
    Norm...I don't think I am experienced enough to use that debug code...
    I have looked back at some other code I have written and have used while/wend the same way.. should I use a pullup on portb.5 to ensure it is high?...I will try that but I think I have already..
    Thanks for helping me figure this out...
    Oct 2008
    I guess that was it...the pullup resistor on the input...apparently it was floating...
    Hi
    Portb on the 18f2550 has analog inputs. You need to set the those pins to digital.
    Try adding
    ADCON1 = %00111111
    This will make all the analog pins digital, see page 254 data sheet
  1. Very simple question (for someone)
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 27th December 2009, 03:36
  2. A simple and basic question
    By Ted's in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 20:01
  3. SIMPLE question
    Last Post: - 5th February 2008, 19:27
  4. very simple loop question
    Last Post: - 25th January 2006, 07:45
  5. Simple Question
    Last Post: - 14th December 2005, 15:43
