Simple question about While Wend...
Results 1 to 10 of 10
    Oct 2008
    Default Simple question about While Wend...
    I have been trying for a while to get this simple code to work. Can someone tell me why it won't?
    Thanks, Don
    while porta.2 <> 0
    wend
    high portb.6
    porta.2 has pullup installed but led on portb.6 always lights....... isn't it supposed to sit there until porta.2 becomes low?
    Default Re: Simple question about While Wend...
    "<>0" is the equivalent of "= 1" for a hi low read.
    Norm
    Oct 2008
    Right.... while pin 2 is at a high state shouldn't the program stay in the while/wend loop until it goes low and then jump out and turn on the LED?
    Quote Originally Posted by dbachman View Post
    Yes
    Try if not already:
    Read a PortB pin in place of portA to avoid config errors.
    Initialize Low portB.6
    Is the read pin an input?
    Norm
    Oct 2008
    this is the code..
    Trisa = 1
    Trisb = %00100000
    portb = 0
    while portb.5 = 1
    wend
    high portb.4
    Try adding some debugs to see if you can find where the breakdown occurs:
    Trisa = 1
     Trisb = %00100000
     portb = 0
    if portb.5 = 1 then
    SerOut2 cSEROUT_PIN,cBAUD,["PRE HI",13]
    SerOut2 cSEROUT_PIN,cBAUD,["PRE LOW",13]
     while portb.5 = 1
    if portb.5 = 1 then
    SerOut2 cSEROUT_PIN,cBAUD,["LOOP HI",13]
    SerOut2 cSEROUT_PIN,cBAUD,["LOOP LOW",13]
     wend
    if portb.5 = 1 then
    SerOut2 cSEROUT_PIN,cBAUD,["AFT HI",13]
    SerOut2 cSEROUT_PIN,cBAUD,["AFT LOW",13]
     high portb.4
    Norm
    Jan 2013
    Texas USA
    What PIC MCU are you using?
    Should you be using LATB register instead of PORTB register for your High and Low statements?
    Read modify write may be an issue.
    TABSoft
  1. Very simple question (for someone)
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 27th December 2009, 03:36
  2. A simple and basic question
    By Ted's in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 20:01
  3. SIMPLE question
    Last Post: - 5th February 2008, 19:27
  4. very simple loop question
    Last Post: - 25th January 2006, 07:45
  5. Simple Question
    Last Post: - 14th December 2005, 15:43
