Error[128] Help!
Results 1 to 3 of 3
    Default Error[128] Help!
    Hello everyone, i've made a simple program to drive LDC display and this happens:
    Error[128] g:\pickit~1\pic\pbp247\pbppic14.lib 2945: Missing Argument(s)
    Any similar experiences? :/
    Default Re: Error[128] Help!
    Hi and welcome to the forum!
    Probably. It says there are missing arguments so I suspect that's actually the issue.
    You're going to have to post the code so we can se it.
    Oct 2009
    Have you selected the correct PIC from the dropdown list in MCS to match the actual PIC you are using ?
    Are you using MPASM to complile or PicPasic, if using MPSAM you need to comment out the config settings in the INC file for the PIC you are using in the PBP2.xx folder
    Just noticed g:\pickit~1\pic\pbp247\pbppic14.lib - are you using version 2.47 ? - that's a really old version of PBP and will require an old version of MPSAM to compile
  1. Old Chestnut ? - 128 x 64 GLCD
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 12th June 2015, 03:14
  2. 128 bit variable???
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 28th October 2011, 18:39
  3. max 128 + pic 16f877
    By supernono in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 14:45
  4. PIC18F4550 Error[128] Missing Arguments
    By damalu in forum mel PIC BASIC
    Last Post: - 17th November 2008, 22:47
