ADC with independant GND and Vref
Results 1 to 8 of 8
    SWITZERLAND (french speaking)
    Default ADC with independant GND and Vref
    Hello,
    I'm wondering if it is possible to implement an ADC knowing the analog input has no connection to the PIC's VDD & VSS.
    Is this possible?
    Roger
    May 2008
    Italy
    Default Re: ADC with independant GND and Vref
    Is doable using a galvanic isolator.
    Cheers
    Al.
    You mean something like a DC-DC converter?
    Roger
    May 2008
    Italy
    No! Something like the Texas component slyt211. But there are several others doing the same job.
    Cheers
    Al.
    ...but, the SLYT211 is a (miniature) DC-DC converter or am I missing something?
    Roger
    Much simpler would be an external V/F converter that can be close to the source ( LM331 as an oldie ! ) http://www12.fairchildsemi.com/ds/KA/KA331.pdf then an opto-coupler :
    you then just have to measure the incoming frequency ...
    May 2008
    Italy
    It is a galvanic isolator. It is also a DC-DC converter but this is just semantic. You need primarely a galvanic isolation.
    Alain suggestion to use a voltage to frequency converter, is an interesting and cheap approch!
    Cheers
    Al.
    Thanks for all the suggestions.
    I never tried a V/F.
    I'll give it a try
    Roger
  1. ADC missing steps using 1 volt Vref
    By Marv in forum mel PIC BASIC Pro
    Last Post: - 10th January 2012, 17:23
  2. ADC negative VREF on 18F4550 question
    By comwarrior in forum General
    Last Post: - 20th February 2011, 23:00
  3. MPXA4115A ADC vref set_up
    Last Post: - 5th August 2009, 20:04
  4. ADC Vref+ on PIC16F88
    By kblim in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 11:14
  5. ADC Vref
    By srob in forum mel PIC BASIC Pro
    Last Post: - 9th April 2008, 19:07
