Compiler/assembler problems preventing a simple change
Results 1 to 7 of 7
    Jun 2015
    Default Re: Compiler/assembler problems preventing a simple change
    Here's another question that, when answered, may solve my problem:
    -What variables affect the generation of the .hex file by MicroCode Studio, and how can I extract information on them from a .hex file or other product of an earlier compilation?
    As you do not report compilation/assemble errors I'll assume there are none.
    In theory it shouldn't matter which assembler you use - with the proviso that it understands the syntax produced by the compiler.
    Have you compared the two hex files? You should have one changed byte and a couple of changed checksums.
    How sure are you that you are using the correct version of the compiler?
    Yes its possible to change a byte in a hex file, the format is well documented. I beleive there is a overall checksum and one for each line.
    All the variables.
    Does you source include the fuses used for flash programming? If not I guess you manually enter them into your programmer?
    Does your programmer allow you to make modifications?
    Personally, I wouldn't even try to change the hex file, I'd find out whats wrong.
    George
    Oct 2009
    Normally I find that white squares on an LCD is a timing issue. Are you sure you have the correct crystal installed and correct OSC set in the code ?
  1. Compile problems with simple RF remote control example
    By astouffer in forum mel PIC BASIC Pro
    Last Post: - 18th July 2012, 05:22
  2. Replies: 1
    Last Post: - 30th March 2012, 04:13
  3. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 19:53
  4. Compiler problems
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 27th September 2006, 13:03
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
