A/D Conversion Clock Select bits confussion ..
Results 1 to 30 of 30
    Apr 2013
    Default Re: A/D Conversion Clock Select bits confussion ..
    FOSC is Frequency of OSCillator, so if you are using 32MHz internal osc, your fosc is 32MHz if you are using 8MHz external osc then your fosc is 8 MHz and if you are using 4 MHz external with PLL then your FOSC is 16MHz.
    011 and 111 settings are for an internal dedicated oscillator with 1.6us period if I remember correct...
    You can always use fosc/2 timing since faster is generally better. But again, it depends on your timing need. If you don't need a special timing, just choose whatever you like.
    Edit: I'm not sure minimum conversion time but I believe it has to be larger then 10us
  1. Replies: 2
    Last Post: - 23rd April 2013, 17:34
  2. DT_INTS-14 /interrupts enable bits / flag bits
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 19:42
  3. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  4. IF or SELECT
    By RYTECH in forum mel PIC BASIC Pro
    Last Post: - 31st December 2005, 19:31
  5. Need clever way to convert 10 bits to 8 bits
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2005, 16:13
