SSD1306 Include example
Results 1 to 12 of 12
    Boston MA
    Default Re: SSD1306 Include example
    George,
    Labx1.inc is just a hardware abstraction include. It helps make testing on different hardware easy.
    Since we are not using any LED's, LCD's or analog you can delete the Include and compile successfully with only adding:
    ===> DEFINE OSC 20
    or whatever speed you are currently using.
    If you are using analog pins you may also need to include something like DT's "AllDigital" about 3/4 of the way down the page.
    http://www.picbasic.co.uk/forum/show...ght=alldigital
    Tim
    Sep 2005
    France
    Hi timc
    I know this is an old thread... I'm using some parts of your code (first one with small characters). Just changing Init because it doesn't work with my chineese LCD, and added a clear screen because some persistent pixels everywhere when choosing invert display.
    Now it works fine... Just a problem with, I think, speed.
    Using a PIC18F46K22 at 12MHz = ok Same pic at 12MHz x 4 PLL = 48MHz and the display won't go to specific row and line.
    tried : DEFINE SHIFT_PAUSEUS 4 but doesn't work too.
    Someone can help ?
    OK
    Did you include the statement, "DEFINE OSC 48" so PBP knows how to time things?
    Sep 2005
    France
    Yes I did....
    Can't explain this. So... Now I'm using second code source with BIG characters... Working at 48 MHz !
  1. Use of INCLUDE
    By Alexey in forum mel PIC BASIC
    Last Post: - 25th December 2013, 13:51
  2. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 15:40
  3. Where are all the INCLUDE files??
    By Heckler in forum General
    Last Post: - 13th September 2011, 08:27
  4. can't find include file!
    By jimbostlawrence in forum mel PIC BASIC Pro
    Last Post: - 10th November 2009, 08:44
  5. Need to download Include files
    By laflam_p in forum Off Topic
    Last Post: - 2nd September 2009, 13:39
