If you want Larger fonts one approach would be to use the same tables and work from the pixel level. Just make every pixel multiple times the size. The characters do look boxy but easy to read. Here is a start from "C" code:
I hope this gives you a start.Code:FOR j = 0 to 4 step size 'Loop through character byte data FOR k = 0 to 6*size ' Loop through the vertical pixels IF pixelData[j] = 1 then ' k=1 'Check if the pixel should be set <== not correct in PBP FOR l = 0 to size 'The next two loops change the character's size FOR m = 0 to size OLED_pixel x + m, y+k * size + l 'Draws the pixel at x, y Next m Next l end if Next k Next J
