Measuring Period & Hz
Results 1 to 11 of 11
    MaurI's Avatar
    MaurI Guest
    Yes I can use a prescaler but that doesn't change the situation that I don't know how to set a counting period (THE TIME) Because Frequency is number of oscillations per period so I need to know number of impulses and the time in what these impulses appeared. OK then Is it possible to use Timer0 and Timer2 at the same time and stop them at the same time if yes then how. Don't think I'm crazy or stupid I couldn't find an answer to this one.
    brighton
    Hi Mate
    i think the easiest route would be for you to use a hardware frequency
    divider chip the can divide your frequency down to the Khz range and then use the ccp capture or timer 1 and you should be ok
    BTW what frequency range are you gonna use
    Isaac
    MaurI's Avatar
    MaurI Guest
    F range will be around 300kHz to 2MHz
    Well I don't want to use hardware f-divider, because I know that this task can be accomplishet without it but I really can't find any source. But if it comes to that there is no choice I will think of something.
  1. Frecuency Detection
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 4th February 2010, 03:01
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  3. Wheel speed sensor
    By Wax-um in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 02:07
  4. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 09:20
  5. Frequency Generator
    By ExYu in forum Off Topic
    Last Post: - 22nd January 2008, 19:25
