WDT times not as expected 18f46k80
Results 1 to 12 of 12
    Feb 2012
    PERTH AUSTRALIA
    Default Re: WDT times not as expected 18f46k80
    THATS A GOOD POINT - thanks hendrick i never considered that issue
    and that will be an issue in the long run for any type of writes to flash
    it would be good to make the config words read a location in the EErpom , which would not be a problem for change updates
    now is that possible ???
    if you need variable wdt reset times why not have the wdt reset decrement a counter and go back to sleep , and only fully wake when counter = 0 , that way wdt reset is infinitely variable with no flash writes at all
  1. Low power sleep mode 18f46k80
    Last Post: - 7th June 2015, 02:21
  2. POWER ON/OFF key in a matrix keyboard 18F46k80
    By longpole001 in forum General
    Last Post: - 14th March 2015, 15:28
  3. PORTB.3 Input not working as expected.
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 5th March 2013, 10:58
  4. 16F1827 table not behaving as expected
    By J. Mark Wolf in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2011, 01:41
  5. code needs much longer then expected
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 03:03
