DT_INTS-14 (Blinky Light) Help ?
Results 1 to 6 of 6
    May 2012
    Merseyside, UK
    Smile DT_INTS-14 (Blinky Light) Help ?
    Hi All
    I have a little bit of code running on a 16f688 all running great.... I have since added DT's blinky Light code, I have used before all good.... But this time I am losing my Digital Output port RC3 and my ADC Channel AN1.
    I remove the Blinky code and my prog works again.
    Any Ideas
    Anyone
    Thank you for reading
    BR
    Andy
    Default Re: DT_INTS-14 (Blinky Light) Help ?
    Hi
    Did you set the ansel register?
    See the data sheet for which bits control your I/O pins
    ANSEL = %00000001 'for digital set to 0 and for analog 1
    also post your code so we don't have to guess
    May 2012
    Merseyside, UK
    Sorry I forgot to add the code :-
    Any ideas on what I am missing welcome, The two includes are in place and are being used !
    Is placement important ?
    Thank you
    '*  Name    :      TRIP.BAS                                      *
    '*  PIC     : PIC16F688                         *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 29/10/2015                                        *
    '*  Version : 2.0                                               *
    '*  Notes   : 322 Words used                                    *
    '*          : Now has Trip Delay Link                           *
    '*          : and Interupt for flash led                        *                            *
    '*  Process Signal  AN0                                         *
    '*  Alarm Preset    AN1                                         *
    '*  Trip Preset     AN2                                         *
    '*  Flash LED       RC1                                         *
    '*  Delay Trip Lnk  RC2                                         *
    '*  Alarm Relay     RC3                                         *
    '*  Trip Relay      RC4                                         *
    '*  Reset Trip P/B  RC5                                         *
    DEFINE OSC 8              ' Set RC Clock to 8 Megs
    wsave var byte $70 SYSTEM
    'Define ADCIN parameters
    Define  ADC_BITS     10    ' Set number of bits in result
    Define  ADC_CLOCK    3     ' Set clock source (3=rc)
    Define  ADC_SAMPLEUS 50    ' Set sampling time in uS
    ADCON0 = %10000001         ' Enable ADC / Right justify result (1023)
    ANSEL  = %00000111         ' Enable ADC channels AN2-AN0
    CMCON0 = %10000111         ' Disable both comparators
    'Analogs
    PROC_SIG Var word           ' Create PROC_SIG to store result
    ALARM_TRIM Var word         ' Create ALARM_TRIM to store result
    TRIP_TRIM Var word          ' Create TRIP_TRIM to store result
    'Digitals
    ALARM_RLY VAR PORTC.3       ' Alarm Relay
    TRIP_RLY VAR PORTC.4        ' Trip Relay
    TRIP_RST VAR PORTC.5        ' Trip Reset PB
    TRIP_DLY VAR PORTC.2        ' Trip Delay Link
    FLASH_LED var PORTC.1       ' Flashy LED
    'Constants
    RLY_OFF CON 0               ' Relay Off
    RLY_ON CON 1                ' Relay On
    HYS CON 8                   ' 25 = 1/8Volt
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    T1CON = $31                ; Prescaler = 8, TMR1ON
    MAIN:
    START:
    LOW TRIP_RLY                ' Ensures Trip Rly off
    'LOW ALARM_RLY               ' Ensures Alarm Rly off
    Gosub ANALOG_READ
    If (ALARM_RLY = RLY_OFF) AND (PROC_SIG >= (ALARM_TRIM + HYS)) THEN ALARM_RLY = RLY_ON
    If (ALARM_RLY = RLY_ON) AND (PROC_SIG <= (ALARM_TRIM - HYS)) THEN ALARM_RLY = RLY_OFF
    If (TRIP_RLY = RLY_OFF) AND (PROC_SIG >= (TRIP_TRIM)) and TRIP_DLY = 0 THEN goto D_TRIP
    If (TRIP_RLY = RLY_OFF) AND (PROC_SIG >= (TRIP_TRIM)) AND TRIP_DLY = 1 THEN goto L_TRIP
    GOTO START
    L_TRIP:                     ' Latching Trip
    high TRIP_RLY               ' Latch Trip Relay
    IF TRIP_RST = 0 THEN GOTO START     'Release If PB Reset  Pressed
    Goto L_trip
    D_TRIP:                     ' Delayed Trip
    HIGH TRIP_RLY               ' Latch Trip Relay
    PAUSE 1000                  ' Pause for T_Delay
    GOTO START
    ANALOG_READ:                ' Read analogs
    ADCIN 0, PROC_SIG           ' Read channel 0 to PROC_SIG
    Pause 2                     ' ADC Settle time
    ADCIN 1, ALARM_TRIM         ' Read channel 1 to ALARM_TRIM
    ADCIN 2, TRIP_TRIM          ' Read channel 2 to TRIP_TRIM
    goto MAIN
    ToggleLED1:
         TOGGLE FLASH_LED
    @ INT_RETURN
    I don't see any tris statements? I know PBP sets some automatically, but it is a good habit
    to manually set them.
    that doesn't set any clock ... just tell the compiler to adjust the timings for a 8 Mhz clock ...
    sooo, clock settings are missing ...
    default settings are ...
        __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    is that what you want ???
    May 2012
    Merseyside, UK
    Stand down folks..... I sorted it :-
    Was commented out.... I forgot to put it back.
    Thanks for all suggestions .... Appreciated as always
    BR
    Andy
  1. Replies: 3
    Last Post: - 15th April 2015, 04:58
  2. DT-INTs Blinky Light question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 03:29
  3. Blinky not working with TOGGLE
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 08:45
  4. My first Blinky!
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th September 2007, 17:29
  5. An other newby, an other blinky probem
    By Maniac in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2005, 15:16
