Problem interfacing ADXL202 and Accustar Clinometer with 16F876A
Results 1 to 12 of 12
    As you use MAX ic, you don't need to use N9600... use T9600 instead
    But that will not solve your problem with Hyperterminal. There's for sure a way to make that software work but i never spend the time to work with. I prefer to use MicroCode Studio to edit my code and use the Serial Communicator window. It's so easy to use.
    you download the free version of MicroCode Studio here
    more info
    here
    Beatrix's Avatar
    Beatrix Guest
    Thanks, I'll try Microcode Studio later when I'm able to. Oh, and I'm NOT using the MAX IC, so I think I need to use N9600....right?
    You're right. With a resistor in serie that will work.
    Beatrix's Avatar
    Beatrix Guest
    Quote Originally Posted by mister_e
    Hmm..that might be part of my problem. Right now I have pin C6 connected to pin 3 of the RS232 connector and pin C7 connected to pin 2 directly (no resistor in series). What resistor would you recomend? That and would I need to use any of the other pins on the RS232 connector (request to send, etc) if just reading trhe data via HyperTerminal or Microsode Studio?
    Feb 2004
    Germany
    Quote Originally Posted by Beatrix
    Beatrix,
    On the second PIC (I guess that's the one to transfer data to the PC) you are using PortB.0 with SERIN
    I assume that's the incomming Data from the first PIC.
    And you are using PortC.7 with SEROUT
    I assume that's the outgoing Data to the PC.
    A series resistor is not really required on the PC's RX-Pin.
    (But 1k wouldn't hinder either)
    Since the PIC does not receive any Data from the PC
    you don't need a connection between PortC.6 and Pin3 on the RS232.
    If you want to connect it you should have a series resistor (say 22k).
    All you actually need are two wires:
    PortC.7 to RS232 Pin 2
    and
    PIC GND (Vss) to RS232 Pin 5
    Is it probably the missing GND that is causing the Problem?
    Set the Handshake in Hyperterm to "NONE"
    Simple test of your PCs serial Port:
    With nothing connected to the RS232
    In Hyperterm set "Local Echo" to "OFF"
    when type on your keyboard there should nothing appear on your screen.
    Now connect Pin 2 and Pin 3 on the RS232
    every character typed should be echoed back on the screen.
    regards
    Ralph
    Beatrix's Avatar
    Beatrix Guest
    Regarding the connection to ground: currently I have both of the Vss pins connected to board ground. For this connection to RS232 ground, should I simply solder in a wire, thereby having Vss connected to board ground and RS232 ground, or should I disconnect it from board ground and only connect it to RS232 ground?
    Feb 2004
    Germany
    ...having Vss connected to board ground and RS232 ground...
    That's the way it should be.
    regards
    Ralph
