Problem interfacing ADXL202 and Accustar Clinometer with 16F876A
Results 1 to 12 of 12
    Beatrix's Avatar
    Beatrix Guest
    Default Problem interfacing ADXL202 and Accustar Clinometer with 16F876A
    I'm a student learning my way around PICBasic Pro (using a copy
    licensed to my school), and I'm having some problems accessing data
    via HyperTerminal. Specifically I'm trying to read data from two
    AXDL202 accelerometers and one MSI Sensors Accustar Serial Clinometer
    being sent to a PIC16F876A. The three sensors send information to one
    876A, which transmits the data serially via RF to another 876A, which
    I would like to read via Hyperterminal. Unfortunately though, when I
    connect to HyperTerminal, I'm not receiving any data, and I have
    tested my RF so I know that it is working properly. In addition, I'm
    using pins C6 and C7 to connect to the RS232 connectior without a MAX
    chip since I seem to recall reading somewhere that those pins can be
    used as an internal RS232 buffer to switch the voltage logic.
    My code is as follows (I didn't include the initials/variable sections for brevity sake):
    First 876A)
    accelmeasX1:
    pulse_a1x_T2 = 0 'find T2
    pulsin xout_a1, 1, pulse_a1x_t1
    pulsin xout_a1, 0, temp_x1
    pulse_a1x_t2 = pulse_a1x_t2 + temp_x1
    pulse_a1x_t2 = pulse_a1x_t2 + pulse_a1x_t1
    pulse_a1x_t2 = pulse_a1x_t2 / 10
    pulsin xout_a1, 1, pulse_a1x_t1 'read T1
    accel1x = (pulse_a1x_t1 / pulse_a1x_t2)
    accel1x = accel1x - half_duty
    accel1x = accel1x / duty_div
    pause 10
    goto accelmeasx1
    accelmeasY1:
    pulse_a1y_T2 = 0 'find T2
    pulsin yout_a1, 1, pulse_a1y_t1
    pulsin yout_a1, 0, temp_y1
    pulse_a1y_t2 = pulse_a1y_t2 + temp_y1
    pulse_a1y_t2 = pulse_a1y_t2 + pulse_a1y_t1
    pulse_a1y_t2 = pulse_a1y_t2 / 10
    pulsin yout_a1, 1, pulse_a1y_t1 'read T1
    accel1y = (pulse_a1y_t1 / pulse_a1y_t2)
    accel1y = accel1y - half_duty
    accel1y = accel1y / duty_div
    pause 15
    goto accelmeasy1
    accelmeasX2:
    pulse_a2x_T2 = 0 'find T2
    pulsin xout_a2, 1, pulse_a2x_t1
    pulsin xout_a2, 0, temp_x2
    pulse_a2x_t2 = pulse_a2x_t2 + temp_x2
    pulse_a2x_t2 = pulse_a2x_t2 + pulse_a2x_t1
    pulse_a2x_t2 = pulse_a2x_t2 / 10
    pulsin xout_a2, 1, pulse_a2x_t1 'read T1
    accel2x = (pulse_a2x_t1 / pulse_a2x_t2)
    accel2x = accel2x - half_duty
    accel2x = accel2x / duty_div
    pause 20
    goto accelmeasx2
    accelmeasY2:
    pulse_a2y_T2 = 0 'find T2
    pulsin yout_a2, 1, pulse_a2y_t1
    pulsin yout_a2, 0, temp_y2
    pulse_a2y_t2 = pulse_a2y_t2 + temp_y2
    pulse_a2y_t2 = pulse_a2y_t2 + pulse_a2y_t1
    pulse_a2y_t2 = pulse_a2y_t2 / 10
    pulsin yout_a2, 1, pulse_a2y_t1 'read T1
    accel2y = (pulse_a2y_t1 / pulse_a2y_t2)
    accel2y = accel2y - half_duty
    accel2y = accel2y / duty_div
    pause 25
    goto accelmeasy2
    'for tilt #1
    init_clin1:
    Low TiltReady1
    low TiltReq1
    If TiltReady1 = 1 then
    goto req_clin1
    goto init_clin1
    pause 25
    req_clin1:
    'while cnt < 17
    high TiltReq1
    if TiltReady1 = 1 then
    goto clin1_prep
    goto req_clin1
    clin1_prep:
    if TiltReady1 = 0 then
    goto clin1_work
    goto clin1_prep
    clin1_work:
    If tiltReady1 = 0 then
    tiltreq1 = 0
    if tiltready1 = 1 then
    goto clin1_data
    goto clin1_work
    clin1_data:
    high Tiltready1
    goto clin1_send
    clin1_send:
    Tiltdata1 = clin_data1
    goto req_clin1
    ' cnt = cnt + 1
    'wend
    goto init_clin1
    'for tilt #2
    init_clin2:
    Low TiltReady2
    low TiltReq2
    If TiltReady2 = 1 then
    goto req_clin2
    goto init_clin2
    pause 25
    req_clin2:
    'while cnt2 = 17
    high TiltReq2
    if TiltReady2 = 1 then
    goto clin2_prep
    goto req_clin2
    clin2_prep:
    if TiltReady2 = 0 then
    goto clin2_work
    goto clin2_prep
    clin2_work:
    If tiltReady2 = 0 then
    tiltreq2 = 0
    if tiltready2 = 1 then
    goto clin2_data
    goto clin2_work
    clin2_data:
    high Tiltready2
    goto clin2_send
    clin2_send:
    Tiltdata2 = clin_data2
    goto req_clin2
    ' cnt2 = cnt2 + 1
    ' wend
    goto init_clin2
    btnclk:
    'for buttons
    Clk_str1 = 0
    clk_str2 = 0
    if click1 = 1 then
    clk_str1 = 1
    clk_str1 = 0
    if click2 = 1 then
    clk_str2 = 1
    clk_str2 = 0
    goto btnclk
    Send_Data:
    'for sending to tx
    serout porta.0, n9600, ["ATJHSD"]
    serout porta.0, n9600, [accel1x]
    pause 5
    serout porta.0, n9600, ["BSDFGF"]
    serout porta.0, n9600, [accel1y]
    pause 5
    serout porta.0, n9600, ["CTERT"]
    serout porta.0, n9600, [accel2x]
    pause 5
    serout porta.0, n9600, ["DDFGHT"]
    serout porta.0, n9600, [accel2y]
    pause 5
    serout porta.0, n9600, ["EVBNRG"]
    serout porta.0, n9600, [clin_data1]
    pause 5
    serout porta.0, n9600, ["FPOEQUY"]
    serout porta.0, n9600, [clin_data2]
    pause 5
    serout porta.0, n9600, ["GGHBDG"]
    serout porta.0, n9600, [clk_str1]
    pause 5
    serout porta.0, n9600, ["HDFYEB"]
    serout porta.0, n9600, [clk_str2]
    pause 5
    goto send_data
    Second 876A)
    incoming:
    serin portb.0, n9600, 1000, ser_error, ["ATJHSD"], Accel1x
    pause 5
    serin portb.0, n9600, 1000, ser_error, ["BSDFGF"], Accel1y
    pause 5
    serin portb.0, n9600, 1000, ser_error, ["CTERT"], Accel2x
    pause 5
    serin portb.0, n9600, 1000, ser_error, ["DDFGHT"], Accel2y
    pause 5
    serin portb.0, n9600, 1000, ser_error, ["EVBNRG"], Clin_data1
    pause 5
    serin portb.0, n9600, 1000, ser_error, ["FPOEQUY"], Clin_data2
    pause 5
    serin portb.0, n9600, 1000, ser_error, ["GGHBDG"], Clk_str1
    pause 5
    serin portb.0, n9600, 1000, ser_error, ["HDFYEB"], Clk_str2
    pause 5
    ser_error:
    goto incoming
    calc_accel1: 'using pyth triangle
    Accel1x = Accel1x * accel1x
    accel1y = accel1y * accel1y
    accel_1 = accel1x + accel1y
    accel_1 = sqr(accel_1)
    calc_accel2: 'using pyth triangle
    accel2x = accel2x * accel2x
    accel2y = accel2y * accel2y
    accel_2 = accel2x + accel2y
    accel_2 = sqr(accel_2)
    calc_pos1: 'x=(1/2)at^2
    time = 5
    time = time * time
    half = 1 / 2
    pos1 = half * Accel_1
    pos1 = pos1 * time
    'if pos > ? then
    calc_pos2:
    time = 5
    time = time * time
    pos2 = half * Accel_2
    pos2 = pos2 * time
    send_data:
    serout portc.7, n9600, ["M"]
    serout portc.7, n9600, [Accel_1]
    pause 5
    serout portc.7, n9600, [Accel_2]
    pause 5
    serout portc.7, n9600, [Clin_data1]
    pause 5
    serout portc.7, n9600, [clin_data2]
    pause 5
    serout portc.7, n9600, [pos1]
    pause 5
    serout portc.7, n9600, [pos2]
    pause 5
    goto send_data
    As I said, I'm still learning PBP, so I'm sure that my problem of not
    reading any data in HyperTerminal could very well be a gross error
    I'm making (I'm using Hellebuyck's PIC Microcontrollers book as a reference). I
    was hoping that someone here could point me in the right direction
    please? Sorry if this is a simple problem, but I just can't seem to
    figure it out.
    Thanks!
    As you use MAX ic, you don't need to use N9600... use T9600 instead
    But that will not solve your problem with Hyperterminal. There's for sure a way to make that software work but i never spend the time to work with. I prefer to use MicroCode Studio to edit my code and use the Serial Communicator window. It's so easy to use.
    you download the free version of MicroCode Studio here
    more info
    here
    Beatrix's Avatar
    Beatrix Guest
    Thanks, I'll try Microcode Studio later when I'm able to. Oh, and I'm NOT using the MAX IC, so I think I need to use N9600....right?
    You're right. With a resistor in serie that will work.
    Beatrix's Avatar
    Beatrix Guest
    Quote Originally Posted by mister_e
    Hmm..that might be part of my problem. Right now I have pin C6 connected to pin 3 of the RS232 connector and pin C7 connected to pin 2 directly (no resistor in series). What resistor would you recomend? That and would I need to use any of the other pins on the RS232 connector (request to send, etc) if just reading trhe data via HyperTerminal or Microsode Studio?
    Feb 2004
    Germany
    Quote Originally Posted by Beatrix
    Beatrix,
    On the second PIC (I guess that's the one to transfer data to the PC) you are using PortB.0 with SERIN
    I assume that's the incomming Data from the first PIC.
    And you are using PortC.7 with SEROUT
    I assume that's the outgoing Data to the PC.
    A series resistor is not really required on the PC's RX-Pin.
    (But 1k wouldn't hinder either)
    Since the PIC does not receive any Data from the PC
    you don't need a connection between PortC.6 and Pin3 on the RS232.
    If you want to connect it you should have a series resistor (say 22k).
    All you actually need are two wires:
    PortC.7 to RS232 Pin 2
    and
    PIC GND (Vss) to RS232 Pin 5
    Is it probably the missing GND that is causing the Problem?
    Set the Handshake in Hyperterm to "NONE"
    Simple test of your PCs serial Port:
    With nothing connected to the RS232
    In Hyperterm set "Local Echo" to "OFF"
    when type on your keyboard there should nothing appear on your screen.
    Now connect Pin 2 and Pin 3 on the RS232
    every character typed should be echoed back on the screen.
    regards
    Ralph
