Take this action when these numbers are reached. How?
Results 1 to 10 of 10
    Jan 2010
    Default Take this action when these numbers are reached. How?
    Is there a way to select an action when a specific number is reached in a counter?
    For example, if I write:
    counter = 0
    loophere:
     if counter = 21 then counter = 0
    counter = counter + 1
    goto loophere
    What I would like to do is along the lines of:
    if counter = 2 or 4 or 6 or 8 or 10 then
    led1 = 1
    led1 = 0
    if counter = 12 or 14 or 16 or 18 or 20 then
    led2 = 1
    led2 = 0
    I know you can write individual lines such as:
    if (counter = 2) OR (counter = 4) OR (counter = 6)...then
    or
    if counter = 2 then
    led1 = 1
    led1 = 0
    if counter = 4 then
    led1 = 1
    led1 = 0
    And so on, but that eats up too much space. Just looking for someone to point me in the right direction. It's late and I'm drawing a blank as to which method to use to save space, but still get it done.
    Tony
    Default Re: Take this action when these numbers are reached. How?
    select case counter
    case 2
    do stuff
    case 4
    do other stuff
    case else
    do something else
    end select
    Jan 2010
    Unfortunately, this is part of a bigger piece of code and right now, I am jumping from a section of code via gosub and running through three gosub subroutines before heading back to the main code. The pic has to read it as the conversation would be spoken: if the counter equals 2 or 4 or 6 or 8 or 10 then turn LED1 on. If it's neither of these numbers, then turn it off.
    select case counter
    case 2
    led1 = 1
    case 4
    led1 = 1
    case 6
    led1 = 1
    case 8
    led1 = 1
    case 10
    led1 = 1
    case else
    led1 = 0
    end select
    or
    if (counter = 2 )| (counter = 4) |,,,,, etc then
    led1 = 1
    led1 = 0
    Jan 2010
    led1 = 1
    led1 = 0
    That's the simplest way huh? I guess being tired didn't matter. Thanks for the help.
    Tony
    it depends on how high count goes up to and wether it starts at 0
    eq if the count was between 1 and 10 then all that's required is to check bit0 if it set then count is odd therefore led1 is off
    Perhaps something like;
    If Counter < 11 THEN
      If Counter // 2 = 0 THEN
        LED1 = 1
        LED0 = 0
      IF Counter // 2 = 0 THEN
        LED2 = 1
        LED2 = 0
    Apr 2011
    Welches, Oregon
    Can you do something like?
    If Counter< 10 then LED1 = Counter.0 : LED2 = NOT LED1
    Hi Tony. How about
    counter var byte
    clear 'all variables
    let portb =0 'off everything
    loophere:
    if counter = (your maximum number) then let counter = 0
    let counter = (counter + 1)
    let portb = counter
    goto loophere
    You will have a binary output on portb and can use the appropriate pins depending on the counter number.
    Jan 2010
    Due to the complexity of the rest of the code, I have the main code setting the pause time. The three gosub commands I have written will be immediate, so as not to interfere with the timing cycle of the aforementioned pause.
    I have multiple outputs being controlled by two inputs. The outputs must reflect what the inputs are doing in real time, however, two of the outputs must run this code and not affect the timing of the rest of the outputs. A third set of outputs will execute another routine, but that code has already been written and tested. This is the last piece I have to finish.
    Using the method I mentioned above, it adds 240 words to my assembly. The way I came up for this program to work in my setup is to have the counter increment with each pass. Half of the count will be dedicated to LED1 and the other half to LED2. It will simply alternate flash the way the code is written.
    As I said, the timing portion is set by the main code, so no delays are in these subroutines, and hence, not affect the real time reflection of the inputs.
  1. Inverting numbers
    By Picstar in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2011, 14:36
  2. Numbers
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 7th April 2007, 19:32
  3. Action on line sync
    By hansknec in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2006, 14:42
  4. Displaying numbers
    Last Post: - 21st March 2006, 00:14
  5. Help, Please....! :-( it is about numbers.
    By megamidi in forum General
    Last Post: - 8th December 2005, 23:44
