Using external EEprom - need a little guidance
Results 1 to 11 of 11
    Oct 2009
    Default Using external EEprom - need a little guidance
    Guys, having a blonde moment here....
    I want to save data to an external chip, a 24c256 EEPROM, but I can't seem to make it work the way I currently save data to the flash in the PIC.
    Using a DS1307 RTC as an example I2CWrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCY ear,RTCCtrl] works fine as each time the update is made it writes the complete string of variables so they remain in the correct order when read back. However I have used designated memory locations eg
    WRITE  $50,lightsetHR[0],lightsetMN[0],lightoffHR[0],lightoffMN[1],word droptemp[0] ,word normtemp[0],StartMin[0],StopHour[0],StopMin[0],word alarmhigh[0],StartHour[0],word alarmlow[0]
    write  $60,lightsetHR[1],lightsetMN[1],lightoffHR[1],lightoffMN[1],word droptemp[1] ,word normtemp[1],StartMin[1],StopHour[1],StopMin[1],word alarmhigh[1],StartHour[1],word alarmlow[1]
    How would I impliment this so it uses the 24c256, do I use the second hex address in the I2CWrite SDApin,SCLpin,$D0,$00, statement thus:
    I2CWrite SDApin,SCLpin,$A0,$50 [lightsetHR[0],lightsetMN[0],lightoffHR[0],lightoffMN[1],word droptemp[0] etc etc...]
    I2CWrite SDApin,SCLpin,$A0,$60 [lightsetHR[1],lightsetMN[1], etc etc...... ]
    Oct 2009
    Default Re: Using external EEprom - need a little guidance
    When I use
    I2CWrite SDApin,SCLpin,$A0,$00,[lightsetHR[0],lightsetMN[0],lightoffHR[0],lightoffMN[1],word droptemp[0] ,word normtemp[0],StartMin[0],StopHour[0],StopMin[0],word alarmhigh[0],StartHour[0],word alarmlow[0]]
    It haults with a "bad expression" error when i attempt to compile, with lots of expected [ and ] !! - but all I've added are the [ and ] at the end of the variable string
    Jan 2013
    Texas USA
    Scampy,
    A couple of things for I2CWrite for sEEPROMs.
    1. For the Address, per the manual do not use Constants. Use a variable of the size required by the EEPROM. A 24c256 requires a Word address.
    2. When using arrays in I2C you need to use var(0) versus var[0]. This is what is causing all of your compile errors.
    3. You are writing all of these values in a string to the sEEPROM, known as Page Write mode. Make sure that the total BYTES sent to the sEEPROM at one time
    does not exceed its page write buffer. For the 24c256 it is 64 bytes.
    4. Remember the sEEPROMS deal with data on a Byte basis. So for your example if I remember correctly your variables you are writing are WORD variables.
    So make sure you x2 when counting the number of BYTES sent to the sEEPROM in Page Write mode.
    This should get you going.
    i2Addr var word
    i2Addr = $00
    i2cwrite SDA, SCL, $A0, i2Addr, [lightsetHR(0),lightsetMN(0),lightoffHR(0),lightoffMN(0),droptemp(0),normtemp(0), _
    StartMin(0),StopHour(0),StopMin(0),alarmhigh(0),StartHour(0),alarmlow(0)]
    This will be 24 bytes. Remember the 24c256 is arranged/addressed in rows of 16 bytes. So this data will start at addr $00 and end at addr $17. (0-23).
    The start addr of your next record would be $18.
    TABSoft
    Oct 2009
    Thanks for the guidance.
    In replacing the square brackets with round ones, would I also need to change the numeric value too to reflect the array format
    normtemp          VAR WORD[4]                   ' used to store the desired temperature setting
      normtemp1       VAR normtemp[0]
      normtemp2       VAR normtemp[1]
      normtemp3       VAR normtemp[2]
      normtemp4       VAR normtemp[3]
    So that normtemp[0] becomes normtemp(1)
    Oct 2009
    I still get the bad expression errors with the following
    i2cread SDA, SCL, $A0, $00,[lightsetHR(1),lightsetMN(1),lightoffHR(1),lightoffMN(1),word droptemp(1) ,word normtemp(1),StartMin(1),StopHour(1),StopMin(1),word alarmhigh(1),StartHour(1),word alarmlow(1)]
    i2cread SDA, SCL, $A0, $18,[lightsetHR(2),lightsetMN(2),lightoffHR(2),lightoffMN(2),word droptemp(2) ,word normtemp(2),StartMin[2],StopHour(2),StopMin(2),word alarmhigh(2),StartHour(2),word alarmlow(2)]
    i2cread SDA, SCL, $A0, $36,[lightsetHR(3),lightsetMN(3),lightoffHR(3),lightoffMN(3),word droptemp(3) ,word normtemp(3),StartMin(3),StopHour(3),StopMin(3),word alarmhigh(3),StartHour(3),word alarmlow(3)]
    i2cread SDA, SCL, $A0, $54,[lightsetHR(4),lightsetMN(4),lightoffHR(4),lightoffMN(4),word droptemp(4) ,word normtemp(4),StartMin(4),StopHour(4),StopMin(4),word alarmhigh(4),StartHour(4),word alarmlow(4)]
    Expected "]" but there is one at the end of the statement...
    Edit:
    Even when I corrected the StartMin[2] user error ! - still get the same !!
    Oct 2009
    It seems that as soon as I include the WORD statement it errors.
    i2cread SDApin, SCLpin, $A0, $00,[lightsetHR(1),lightsetMN(1),lightoffHR(1),lightoffMN(1)]
    compiles fine, but
    i2cread SDApin, SCLpin, $A0, $00,[lightsetHR(1),lightsetMN(1),lightoffHR(1),lightoffMN(1),word droptemp(1),word normtemp(1)]
    caused the Error:Expected"]" error message
    Stumped !!!
    Oct 2009
    The manual states
    If a word- or long-sized array is specified, the bytes that comprise each element are
    read lowest byte first. This is the opposite of how simple words and longs are read
    and is consistent with the way the compiler normally stores word- and long-sized
    variables.
    How would I impliment this low.byte / high.byte with an array variable ?
    Aug 2008
    Portugal
    Hi Scampy;
    Here is a code i do some time go to interface a 93c46 using both MSSP and Shift. Hope ot will be useful to you;
    '*  Name    : 93C46N EEPROM + MSSP                              *
    '*  Author  : [GADELHAS]                                        *
    '*  Notice  : Copyright (c) 2012                                *
    '*  Date    : 08-02-2012                                        *
    '*          : EASYPICV6 + PIC16F887 + 93C46N - FARCHILD         *
    '                              CONFIGS
    @ __CONFIG _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _BOR_OFF & _DEBUG_OFF & _LVP_OFF & _FCMEN_ON & _IESO_OFF
    @ __CONFIG _CONFIG2, _WRT_OFF & _BOR40V
    '                          DEFINES & INCLUDES
     DEFINE OSC 8
    '                REGISTERS AND PINOUT ( 1 = IN; 0 = OUT )
               '76543210          '76543210
     TRISA   = %00000000: PORTA = %00000000
     TRISB   = %00000000: PORTB = %00000000
     TRISC   = %00010000: PORTC = %00000000
     TRISD   = %00000000: PORTD = %00000000
     TRISE   = %00000000: PORTE = %00000000
     ADCON0  = %00000000
     ADCON1  = %00000000
     ANSEL   = %00000000
     ANSELH  = %00000000
     CM1CON0 = %00000000
     CM2CON0 = %00000000
     SSPSTAT = %00000000  'Configures the SPI Module ( Read DataSheet )
     SSPCON  = %00110001  'Configures the SPI Module ( Read DataSheet )
    '                         ALIAS & MODIFIERS
       CS VAR PORTC.1  'Pin 1 of the 93C46N - PDIP CASE ( CS )
      CLK VAR PORTC.3  'Pin 2 of the 93C46N - PDIP CASE ( SK )
      SDI VAR PORTC.4  'Pin 4 of the 93C46N - PDIP CASE ( DO )
      SDO VAR PORTC.5  'Pin 3 of the 93C46N - PDIP CASE ( DI )
    '                        VARIABLES & COSTANTS
     ADDRESS VAR BYTE  'Address position to read or write
         BT0 VAR BYTE  'Byte 0 to read or write
         BT1 VAR BYTE  'Byte 1 to read or write
           I VAR BYTE
    '                              DEFINES
     DEFINE LCD_DREG PORTB       ' LCD Data bits on PORTB
     DEFINE LCD_DBIT 0           ' PORTB starting address
     DEFINE LCD_RSREG PORTB      ' LCD RS bit on PORTB
     DEFINE LCD_RSBIT 4          ' LCD RS bit address
     DEFINE LCD_EREG PORTB       ' LCD E bit on PORTB
     DEFINE LCD_EBIT 5           ' LCD E bit address
     DEFINE LCD_BITS 4           ' LCD in 4-bit mode
     DEFINE LCD_LINES 2          ' LCD has 2 rows
     DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
     DEFINE LCD_DATAUS 50        ' Set data delay time in us
     DEFINE DEBUG_REG PORTC
     DEFINE DEBUG_BIT 6
     DEFINE DEBUG_BAUD 19200
     DEFINE DEBUG_MODE 0
    '                           PROGRAM INIT
                       '0123456789012345
        LCDOUT $FE, 1, " 93C46   EEPROM "
        PAUSE 2000
        DEBUG "Start", 13,10,13,10
    '                            MAIN LOOP
    MAIN:
        FOR I = 0 TO 63
            GOSUB READ2BYTES
            LCDOUT $FE, 1, "Iteracao: ", DEC I
            LCDOUT $FE,$C0,"BT0:", HEX BT0, " - BT1:", HEX BT1
            DEBUG "Iteracao: ", DEC I," - ", HEX BT0,HEX BT1,13,10
        NEXT
        STOP
        GOTO MAIN
    '                              SUB - ROTINES
    WRITE2BYTES:
        CS=1                      'Enable Device
        SSPBUF = $1               'Start Bit
        SSPBUF = $30              'Command to Write
        CS=0                      'Disable Device
        CS=1                      'Select Device
        WHILE SSPSTAT.0=0:WEND    'Wait for the BF flag to be Set
        SSPBUF = $40 | ADDRESS    '01000000 Ored with ADDRESS
        SSPBUF = BT0              'Data 00
        SSPBUF = BT1              'Data 01
        PAUSE 5                   'Insure that you don't work you the device for 5ms
    READ2BYTES:
        CS=1                      'Enable Device
        SSPBUF = $80 | ADDRESS    '10000000 Ored with ADDRESS
        SSPCON.4=0                'Change Signal Clock "DataSheet of the PIC"
        SSPBUF = $0               'Send Something
        BT0=SSPBUF                'Read the SSPBUF to the BT0 Variable
        BT1=SSPBUF   	          'Read the SSPBUF to the BT1 Variable
        SSPCON.4=1                'Change the clock to initial state
    ERASEALL:
        CS = 1                    'Enable Device
        SSPBUF = $20              'Command to Erase ALL
        CS = 0                    'Disable Device
    WRITEALL:
        SSPBUF = $10              'Command to Erase ALL
        SSPBUF = BT0              'Data Pattern 00
        SSPBUF = BT1              'Data Pattern 01
    '*  Name    : 93C46N EEPROM                                     *
    '                              CONFIGS
     DEFINE OSC 8
               '76543210          '76543210
     TRISC   = %10101101: PORTC = %00000000
     ADCON0  = %00000000
     ADCON1  = %00000000
     ANSEL   = %00000000
     ANSELH  = %00000000
     CM1CON0 = %00000000
     CM2CON0 = %00000000
    '                         ALIAS & MODIFIERS
           I VAR BYTE
    '                              DEFINES
     DEFINE DEBUG_BIT 6
     DEFINE DEBUG_MODE 0
    '                           PROGRAM INIT
                       '0123456789012345
        PAUSE 2000
        DEBUG "Start",13,10,13,10
    '                            MAIN LOOP
    MAIN:
        FOR I = 0 TO 63
            GOSUB READ2BYTES
        NEXT
        STOP
        GOTO MAIN
    '                              SUB - ROTINES
    WRITE2BYTES:
        CS = 1
        SHIFTOUT SDO,CLK,1,[%10011,0\4]  'Enable write
        PAUSE 5
        CS = 0
        CS = 1
        SHIFTOUT SDO, CLK, 1, [%101\3,ADDRESS\6,BT0,BT1]  'Two bytes at a time
        PAUSE 5
        CS = 0
    READ2BYTES:
        CS=1
        SHIFTOUT SDO,CLK,1,[%110\3,ADDRESS\6]
        SHIFTIN SDI,CLK,2,[BT0,BT1]  'Two bytes at a time
        PAUSE 5
        CS=0
    ERASEALL:
        CS = 1
        SHIFTOUT SDO,CLK,1,[%10010,0\4]
        PAUSE 5
        CS = 0
    WRITEALL:
        CS = 1
        SHIFTOUT SDO,CLK,1,[%10001,0\4,BT0,BT1]  'Two bytes data pattern
        PAUSE 5
        CS = 0
    Thanks and Regards;
    Gadelhas
    Aug 2008
    Portugal
    Found another one using I2C
    '*  Name    : Ext. EEprom.BAS                                   *
    '*  Notice  : Copyright (c) 2011                   *
    '*  Date    : 14-08-2010                                        *
    '*          : EASYPICV6 + PIC16F887 + LCD 16X2                  *
    @__CONFIG _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _BOR_ON & _DEBUG_OFF & _LVP_OFF & _FCMEN_ON & _IESO_OFF
    @__CONFIG _CONFIG2, _WRT_OFF & _BOR40V
    DEFINE OSC 8
    DEFINE I2C_HOLD 1
    '                               VARIÁVEIS
    I var byte  'VARIÁVEL DOS I2C READ AND WRITE
    buffer var byte[13]
    buffer1 var byte[13]
    buffer[0] = "H"
    buffer[1] = "u"
    buffer[2] = "g"
    buffer[3] = "o"
    buffer[4] = " "
    buffer[5] = "O"
    buffer[6] = "l"
    buffer[7] = "i"
    buffer[8] = "v"
    buffer[9] = "e"
    buffer[10] = "i"
    buffer[11] = "r"
    buffer[12] = "a"
    '                              REGISTOS PINOUT 1 = IN; 0 = OUT
             '76543210
    TRISA  = %00000001
    TRISB  = %00000000
    TRISC  = %00000000
    TRISD  = %00000000
    TRISE  = %00000000
    ADCON0 = 0
    ANSEL  = 0
    ANSELH = 0
    CM1CON0= 0
    CM2CON0= 0
    PORTA = 0
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    '                              NOMES PINOUT
    LED    VAR PORTA.0
    SDA    var PORTC.4
    SCL    var PORTC.3
    '                              DEFENIÇÕES
    '                             INICIO PROGRAMA
    MAIN:
        HIGH LED
        PAUSE 500
        LOW LED
        PAUSE 500
        HIGH LED
        PAUSE 500
        LOW LED
        PAUSE 500
        HIGH LED
                     '0123456789012345
        lcdout $FE, 1, "Teste Ext.EEprom"
        lcdout $FE,$C0," Hugo  Oliveira"
        GOSUB WRITEEEPROM
        GOSUB READEEPROM:
        lcdout $FE,$C0, STR buffer1\13
    '                      SUB ROTINA - LE EEprom
    READEEPROM:
        FOR I = 0 to 12
            i2cread sda,scl,$A3, I,[buffer1[I]]
        NEXT
    '                      SUB ROTINA - ESCREVE EEprom
    WRITEEEPROM:
        FOR I = 0 to 12
            i2cwrite sda,scl,$A2, I,[buffer[I]]
            pause 5
        next
    Thanks and Regards;
    Gadelhas
    Oct 2009
    Thanks for the input Gadelhas,
    I'm not 100% sure if it applies to my issue of writing and reading word array variables to the external eprom. I assume the [Buffer[i]] will be a normal byte variable ??
    Aug 2008
    Portugal
    Quote Originally Posted by Scampy View Post
    I can't confirm, but i acutally think that 24c256is not capable of writting 2 bytes in sequence. You can only wirte one byte, or one page of 64bytes in sequence.
    What is the vendor? Please confirm this information in the datasheet.
    Thanks and Regards;
    Gadelhas
  1. ConnectOne and external EEPROM
    By mackrackit in forum Ethernet
    Last Post: - 23rd June 2011, 00:31
  2. I2C with External Eeprom
    Last Post: - 22nd February 2008, 14:13
  3. external eeprom
    Last Post: - 1st January 2008, 12:11
  4. Simple External EEPROM Table Example?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 20:18
  5. External EEPROM
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 6th July 2006, 22:35
