PIC 18F device suggestion.
Results 1 to 5 of 5
    May 2008
    Italy
    Default Re: PIC 18F device suggestion.
    Why not using a frequency to voltage converter and than use an ADC channel to read the car RPM.
    Cheers
    Al.
    Sao Paulo - Brazil
    Hi !
    Hummmm... Can you Belive I Had never tryed This before !
    I will make some research on converting frequency to voltage on a range from 0v to 5v.
    Thank you for the advice !
    16f1526/7 has a whole bunch of timers.
    Exactly how are the three timers on the 877 used? perhaps you can shuffle them and make it work with just software. I assume existing timer3 doesn't need a trigger input. Maybe 1 or 3 on the 2420 could be used as the timebase.
    George
    Sao Paulo - Brazil
    Hi George,
    thank you for the reply !
    Well, I´m using all 16f877's as described bellow :
    1) TMR0 => Count the number of pulses from the car's wheel.
    2) TMR1/CCP1 => measure the Feel Injector's "On-Time"
    3) TMR2 => This timer is used as a 500ms time base for all calculation and display update.
    I´m using DT Interrupts to deal with the timers.
    May be use the RB change pin interrup to count the RPM events.
    I´m planning to move my project to the ST7735 display, and use the Richard libs available here in the forum. SO, I should move to a 18F series Pic.
    I have here with me, some 18F2420, 18F4550 and 18F2520. I'll try to some of them.
    My best regards !
    Sérgio
  1. Input Capture CAP1 using PIC 18F help !
    By aredhel in forum mel PIC BASIC
    Last Post: - 28th March 2012, 18:21
  2. Pic 18f Usb
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 31st March 2011, 09:51
  3. Suggestion for textbook on PIC microcontrollers
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 16th May 2010, 22:07
  4. First time with 18F pic...
    By gabrielg74 in forum mel PIC BASIC Pro
    Last Post: - 9th December 2005, 08:04
  5. Pic suggestion for high precision voltage measure
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 10th April 2004, 07:22
