Major problem after PC crash
Results 1 to 2 of 2
    Oct 2009
    Default Major problem after PC crash
    Slightly off toppic, but related to PBP installation.
    My PC suffered a crash at the weekend - mainly corrupted file structure, but as a result I've purchased a new drive and started from fresh. I've installed PBP2.60, MSC and MPlab 8.90 (also tried later versions of MPLab). I've set MCS to point to the PBP.exe, MPASM folder (with used MPSAM box checked) and created a custom programmer for PICFLASH which is used with my EasyPIC5 board. But now when I compile, I get a blank DOS box when compiling rather then the small window with the green progress bar.
    I've tried several installations (including a fresh formatted drive) and still get the same issue. - anyone have any ideas ?
    Just to clarify, the DOS box title bar has C:\Progra~\MPASMS~\mpasmwin.exe and no text appears in the box, just a flashing cursor
    Default Re: Major problem after PC crash
    Related thread with some background info. Seems you should be good with a MPLAB version prior to 8.20.
  1. Program crash - how to trace the cause
    By longpole001 in forum PBP3
    Last Post: - 4th April 2014, 00:50
  2. 5 Minute Crash Course On OOP
    By T.Jackson in forum Off Topic
    Last Post: - 28th March 2008, 08:13
  3. The crash is back
    By fowardbias in forum mel PIC BASIC Pro
    Last Post: - 26th June 2007, 15:53
  4. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 04:16
  5. Forum crash ?
    By NavMicroSystems in forum General
    Last Post: - 11th March 2004, 10:11
