Program 3 PICs using one PICKIT 3. Possible?
Results 1 to 9 of 9
    Default Re: Program 3 PICs using one PICKIT 3. Possible?
    Doing a quick Google search, I found..
    http://www.microchip.com/forums/m485958.aspx
    Add: For a small fee Microchip will program your chips at the factory.
    Oct 2009
    Utah, USA
    Talking Re: Program 3 PICs using one PICKIT 3. Possible?
    If I cared about reliability or I had to travel a great distance to fix an issue or it was a commercial product... I would not attempt it.
    For hobbyist stuff... give it a go!!
    Dwight
    I would be somewhat leary of trying to program 3 devices at the same time as there is a handshake process that has to take place during the flash process. If the timing of 1 of the devices is a bit different there could be a conflict. I am assuming you are talking about connecting the PGC, PGD, and RST line's together?
    Also there may be a problem with Loading.
    EN82fn
    @Dave, I'm not sure you are correct re. handshaking. Don't know about LVP but for standard high-voltage programming all I see is clock and data and VIHH on MCLR. Of course you wouldn't be able to verify so I guess you could only use this for novelty items. But if you really had to do this you have the PIC device verify its code space against a checksum.
    George
    Feb 2005
    Holmfirth England
    Thank you all for the replies.
    This is an industrial product, so not worth taking the risk.
    I admit I had not thought about the verify part of programming.
    Bob.
    Hi Bob. I mentioned this in another post a while back. I have programmed 10 PICs at once for use in commercial products BUT the products were tested before releasing them. Simply stack one PIC on top of each other so that all the pins are in parallel and all will program. If you stack say 6 and the 4th one up isn't connected then the chain is broken and 4,5 and 6 won't be programmed. Try it, it works.
    Keep in mind that Pickit is not for production as Microchip states and as I have confirmed.
    From times to times I had chips that were not programmed 100% correctly.
    With other programmers like ICD3 or Elnec Pikprog+ never had a problem of corrupt code.
    Quote Originally Posted by peterdeco1 View Post
    I second this; never had a problem. Been cascading chips like this since the good old 27XX EPROM days.
  1. PicKit 3
    By tazntex in forum General
    Last Post: - 10th May 2011, 12:06
  2. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  3. PICKit 2 USART
    By DragonBall_6 in forum mel PIC BASIC Pro
    Last Post: - 17th December 2008, 16:08
  4. PicKit 2 Questions
    By dmairspotter in forum General
    Last Post: - 11th November 2007, 21:10
  5. Pickit 2 stinks!!
    By mbw123 in forum General
    Last Post: - 25th August 2006, 19:27
