USART2 setting for 1MHzCPU + 4PLL
Results 1 to 33 of 33
    Feb 2012
    PERTH AUSTRALIA
    Default Re: USART2 setting for 1MHzCPU + 4PLL
    so since pbp will only accept 3(3.88mhz) or 4 ( 4mhz) as the define osc , it means all the timed commands such as pause , pauseus , RCtime etc are 4 times longer than shown in code ??????????????
    if no define osc is given then it assumed to be 4mhz
    sort of sucks when u want go low power / osc for a chip
    btw in my application the current draw is as follows with only a osc speed change
    1mhz = 1.04ma - running , sleep mode = 0.24ma for all settings
    2mhz = 1.28ma - running
    4mhz = 1.6 ma - running
    8mhz = 2.23ma - running
    16mhz=3.47ma - running
    16mhz - 4mhz + ppl = 1.6ma
    32mhz - 8mhz + ppl = 5.96ma
    64mhz - 16mhz+ppl = 10.35ma
    when powering the device from a small coin battery and when you dont need the higher speed , 1mhz is a better option
    although0.56ma is not a lot between 1mhz and 4mhz it still is a waist when it not required to be so , just to satisfy PBP compile setting for 4mhz
    cheers
    sheldon
    May 2007
    The proper way to do this (low power consumption for battery use) is to use the low power modes of the MCU and NOT to lower the clock speed.
  1. Micrtochip AN1310 for USART2
    By cerr99 in forum mel PIC BASIC
    Last Post: - 27th May 2011, 18:59
  2. USBBufferSize setting
    By Ronald123 in forum USB
    Last Post: - 18th April 2008, 12:33
  3. Setting up the oscillator
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2007, 14:53
  4. setting up HPWM
    By sunny in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2006, 01:36
  5. setting register
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 22:46
