' config for 18F46K80
;----- CONFIG1L Options --------------------------------------------------
    CONFIG XINST     = OFF
    CONFIG SOSCSEL   = DIG        ; Digital (SCLKI) mode; I/O port functionality of RC0 and RC1 is enabled
    CONFIG INTOSCSEL = LOW        ; LF-INTOSC in low-power mode during Sleep
    CONFIG RETEN     = ON         ; Ultra Low power regulator is Enabled  (Controlled by SRETEN bit)when in sleep
;----- CONFIG1H Options --------------------------------------------------
    CONFIG IESO      = OFF
    CONFIG FCMEN     = OFF
    CONFIG PLLCFG    = OFF
    CONFIG FOSC      = INTIO2     ; Internal RC oscillator  , PORTA.6 , PORTA.7 as I/O
;----- CONFIG2L Options --------------------------------------------------
    CONFIG BORPWR    = ZPBORMV    ; ZPBORMV instead of BORMV is selected
    CONFIG BORV      = 2          ; 2V
    CONFIG BOREN     = SBORDIS    ; Enabled in hardware, SBOREN disabled
    CONFIG PWRTEN    = OFF
;----- CONFIG2H Options --------------------------------------------------
    CONFIG WDTPS     = 512        ; 1:512
    CONFIG WDTEN     = OFF        ; WDT Off
;----- CONFIG3L Options --------------------------------------------------
; no register in the device
;----- CONFIG3H Options --------------------------------------------------
    CONFIG MCLRE     = ON         ; MCLR ENabled FOR DIAG , RG5 DISabled
    CONFIG MSSPMSK   = MSK7       ; 7 Bit address masking mode
    CONFIG CANMX     = PORTB      ; ECAN TX and RX pins are located on RB2 and RB3, respectively
;----- CONFIG4L Options --------------------------------------------------
    CONFIG BBSIZ     = BB1K       ; 1K word Boot Block size
    CONFIG STVREN    = ON
;----- CONFIG5L Options --------------------------------------------------
    CONFIG CP0       = ON         ;  MEMORY BLOCK 0 CODE PROTECT BIT - 7KW 800h  - 3FFFh ( when 1K BOOT OPTION used )
    CONFIG CP1       = ON         ;  MEMORY BLOCK 1 CODE PROTECT BIT - 8KW 4000h - 7FFFh
    CONFIG CP2       = ON         ;  MEMORY BLOCK 2 CODE PROTECT BIT - 8KW 8000h - BFFFh
    CONFIG CP3       = ON         ;  MEMORY BLOCK 3 CODE PROTECT BIT - 8KW C000h - FFFFh
;----- CONFIG5H Options --------------------------------------------------
   CONFIG  CPD       = OFF        ; EEPROM DATA PREOTECT BIT - EXTERNAL R/W
   CONFIG  CPB       = ON         ; BOOT BLOCK CODE PROTECT BIT
;----- CONFIG6L Options --------------------------------------------------
    CONFIG WRT0      = OFF        ; MEMORY BLOCK WRITE PROTECT BIT
    CONFIG WRT1      = OFF
    CONFIG WRT2      = OFF
    CONFIG WRT3      = OFF
;----- CONFIG6H Options --------------------------------------------------
    CONFIG WRTD      = OFF       ; EEPROM WRITE PROTECT BIT - INTERNAL AND EXTERNAL
    CONFIG WRTB      = ON        ; BOOT BLOCK WRITE PROTECT
    CONFIG WRTC      = ON        ; CONFIGURATION REGISTER WRITE PROTECT BIT
;----- CONFIG7L Options --------------------------------------------------
     CONFIG EBTR0     = OFF      ; MEMORY READ TABLE BLOCK PROTECT
     CONFIG EBTR1     = OFF
     CONFIG EBTR2     = OFF
     CONFIG EBTR3     = OFF
;----- CONFIG7H Options --------------------------------------------------
    CONFIG EBTRB     = OFF      ; TABLE READ PROTECT BOOT
   clear                        ' clear all varables to 0 on startup
' ----------------  Setup All Define statements ------------
    DEFINE OSC 4                ' Timing referance for pause , pauseus commands
    DEFINE ADC_BITS 12          ' Number of bits in ADCIN result - Required for adcin command
    DEFINE PULSIN_MAX 2000      ' Maximum counts( clock ticks) allowed before pulsin times out( 2000 ^ 1.25us =  2.5 ms)
    DEFINE HSER_PORT 2          ' Hser port 2 use
    DEFINE HSER2_RCSTA 90h      ' Hser2 receive status init
    DEFINE HSER2_TXSTA 24h      ' Hser2 transmit status init  ( BIT2 -BRGH 1= HI SPEED, 0= LOW SPEED )
    DEFINE HSER2_CLROERR 1      ' Clear overflow automatically
    DEFINE HSER2_BAUD 19200     ' Hser2 baud rate
    DEFINE HSER2_SPBRG 12       ' 19200 Baud @ SPBRGH = 12 0.16% error
    BAUDCON2.3 = 1              ' set BRG16 = 1 - 16BIT/ASYNC
' ---------- Set up DT_INTS-18 Routine for Instant Interupt handling   -----------
     INCLUDE "DT_INTS-18.bas"       ; Base Interrupt System for 18FxxK80 processors
     INCLUDE "ReEnterPBP-18.bas"    ; Include if using PBP interrupts
INT_LIST macro	; IntSource  ,    Label    , Type, ResetFlag?
   INT_Handler TMR0_INT, _Timer0_Count,  PBP, yes      ; call Timer0_Count subroutine
   INT_Handler  RBC_INT, _Rx_mode_IOC ,  PBP, yes      ; Call Rx_mode_IOC subroutine for RF RX_mode
   INT_Handler  RX2_INT, _Term_RX     ,  PBP, yes      ; Call Term_input for terminal char buffer
   INT_Handler INT0_INT, _Sleep_Over  ,  PBP, Yes      ; Call for INT0 trigger - when exit sleep mode
 INT_CREATE								; Creates the Interrupt Processor
 '----------- 18F46K80  - PIC chip Dephalt settings --------------------
   OSCCON   = %00110000     ' Select 1Mhz - using 1Mhz internal with PPLx4 in Config1H<3:0>  =  IDLEN =0 , 8Mhz , OSTS=0,RFIOFS=1,RC_Run (1x) OSC using PLL
                            ' Bit 7 IDLEN =0 ( sleep mode when sleep instraction executed)
                            ' Bits 6-4 -  111 = 16Mhz , 110 = 8MHz ,101 = 4 MHz, 100 = 2MHz 011 = 1MHz
                            ' If INTTSRC=0 and MFIOSEL= 0 then 010 = HF-INTOSC/32 (500Khz), 001 = HF-INTOSC/64 (250Khz) ,000 = LF-INTOSC     (31.25Khz)
                            ' If INTTSRC=0 and MFIOSEL= 1 then 010 = MF-INTOSC    (500Khz), 001 = MF-INTOSC/2  (250Khz) ,000 = LF-INTOSC     (31.25Khz)
                            ' If INTTSRC=1 and MFIOSEL= 0 then 010 = HF-INTOSC/32 (500Khz), 001 = HF-INTOSC/64 (250Khz) ,000 = HF-INTOSC/512 (31.25Khz)
                            ' If INTTSRC=1 and MFIOSEL= 1 then 010 = MF-INTOSC    (500Khz), 001 = MF-INTOSC/2  (250Khz) ,000 = MF-INTOSC/16  (31.25Khz)
                            ' Note: INTSRC = OSCTUNE<7> and MFIOSEL = OSCCON2<0>
                            ' Bit 3 - OSTS = 0 - Osc startup time out  is ruinning from internal OSC ( HF, MF or LF-INTOSC)
                            ' Bit 2 - HFIOFS =1 ( INTOSC Frq stable bit  -  1 = stable , 0 = not stable
                            ' Bits 1-0 - 00= Dephalt Pri OSc ( OSC1/2 or HF-INTOSC with/without PLL set in FOSC,3:0> config1H <3.0>
                            '            01 = SOSC osc
                            '            1x = Internal osc ( LF, MF,HF-INTOSC)
  ' OSCCON2 = $00            ' Bit 7 n/a , Bit 6 - SOSCRUN - Run status bit , Bit 5-4 n/a,
                            ' Bit 3 = SOASCGO - Osc Start control bit 1 = OSC running , 0 = OSC shut off if no requests for it
                            ' Bit 2 n/a , Bit 1 - MFIOFS 1= MFINTOSC stable  0 = Not stable
                            ' Bit 0 MFIOSEL - 1 = MF-INTOSC replaces HF-ISTOSC Freq for 500Khz,250Khz,31.25KHz) 0 = MF-INTOSC not used
   OSCTUNE = %01000000      ' Bit 7  - INTSRC - internal LF Source Select 1 = 31.25 from 16Mhz Internal /512 HF-INTOSC ) 0 = Internal 31khz OSC
                            ' Bit 6 - PLLEN - 1 PLL enabled  , 0 = PLL disabled
                            ' Bits 5-0 Frequancy callibaration 00000 = centre Frq
   WDTCON = %00010000       ' use ultra low power mode when in sleep - disable  regulator in sleep mode
                            ' Bit7 = REGSLP- Regulator Voltage Sleep Enable - 1= Reg goes into low-power Mode when in sleep mode ,0 = Reg stay in normal mode
                            ' Bit6= n/a , Bit5 = ULPLVL - Ultra lowpower Wakeup output sel 1= Vout on RA0 0= Vout on RA1 ( no effect if WDTEN in config is set  )
                            ' Bit4= SRETEN = Regulator Volt Sleep Disable bit - 1= goes into Ultra lOwpower mode in sleep ( CONFIG1L.0 =0 MUST BE SET)
                            ' Bit3=n/a , Bit2 = ULPEN - Ultra Low Power Wakup Module enable 1 = enabled , 0 = disabled
                            ' Bit1=ULPSINK- Ultra Low-power Wakeup Current Sink Enable  1= Sink enabled 0 = Sink disabled ( Not valid if ULPEN=0 )
                            ' Bit0= SWDTEN -Watchdog Timer Enable  = 1= enable watchdog 0 = Disable Watchdog ( no effect if WDTEN in config is set  )
    PSPCON.4 = 0             ' turn off parallel slave port mode - general purpose I/O mode PORTD & PORTE
    INTCON2.6 = 0          ' INTEDG0 - External Interrupt 0 Edge Select - 1= Rising Edge , 0 = Falling Edge
    INTCON2.5 = 0          ' INTEDG1 - External Interrupt 1 Edge Select - 1= Rising Edge , 0 = Falling Edge
    INTCON2.4 = 0          ' INTEDG2 - External Interrupt 2 Edge Select - 1= Rising Edge , 0 = Falling Edge
    INTCON2.3 = 0          ' INTEDG3 - External Interrupt 3 Edge Select - 1= Rising Edge , 0 = Falling Edge
    INTCON3.6 = 0          ' INT1IP  - INT1 External Interupt Priority - 1 = High Priorty , 0 = Low Priority
    INTCON3.7 = 0          ' INT2IP  - INT2 External Interupt Priority - 1 = High Priorty , 0 = Low Priority
    INTCON2.1 = 0          ' INT3IP  - INT3 External Interupt Priority - 1 = High Priorty , 0 = Low Priority
