How many AND / OR are accepted ?
Results 1 to 3 of 3
    Jun 2008
    Varese , Italy
    Default How many AND / OR are accepted ?
    good day ,
    I have a very simple qestion regarding the number of AND and OR can be put in the " if " control under PicbasicPro.
    Eg.: if (a>b) AND (c>d ) AND (e>f) AND (g>h) AND (i>l ) AND ( m>n) AND (o>p) THEN ....
    Ambro
    May 2008
    Italy
    Default Re: How many AND / OR are accepted ?
    I think that the number of Logic are limited by the two line space!
    But you can do the and Logic with nested if/then like this:
    If a>B then
    If c>d then
    If e>F then
    If x>z then
    Code for the Action necessary If all the ands are satisfied
    This type of construct is shorter in terms of ram usage and is much faster than the corresponding "line construct"
    With the same approch you can make the OR construct.
    Naturaly here the limitation is the ram size of your mcu.
    Cheers
    Al.
    Jun 2008
    Varese , Italy
    Thanks for the clarification,
    All the best.
    Ambro
  1. Brown-out symbol not accepted.
    By thronborg in forum mel PIC BASIC Pro
    Last Post: - 30th August 2013, 04:30
  2. 12F675: DEC modifier not accepted
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 03:39
