Serial over Blue Tooth
Results 1 to 8 of 8
    Oct 2009
    Default Serial over Blue Tooth
    I'm updating a project that currently uses standard serial port to communicate to an application on the PC. I actually use a USB to serial FTDI breakout board to make connectivity more straight forward as modern PC's seldom come with RS232 serial ports these days. However as part of my "revamp" I want to replace this connection with a blue tooth option, and have purchased a couple og the HC-06 modules with back board attached and a decent Belkin BT dongle.
    Rather than swap out the USB board and then hope for the best that it works and is a direct replacement I thought I would do some simple testing.
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 40
    ADCON1 = $0F
    clear
    ;----[Hardware USART defines]---------------------------------------------------
    DEFINE HSER_SPBRG 86  ' 115200 Baud @ SPBRGH = 0
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $24   ' Enable transmit, BRGH = 1
    SPBRG = 86    ' 115200 Baud @ -0.22%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    HSEROUT ["Hello"]
    Pause 1000
    Nothing taxing, just a simple "hello world" example. Compiled and loaded the code to the PIC (18f4580) - and tetsed using the existing USB and a windows terminal program... sure enough "Hello" was repeatedly displayed line by line with 1 second intervals. OK over the the BT device. Installed the drivers, and then searched and found the HC-06, connected and paired successfully. Opened the windows terminal program and selected the com port and settings - I get a listing, but it's just a 1 in the ascii dump and FB in the hex window.
    I know i've got the correct port as I can remove the connection wire between the PIC and the HC-06 and it stops scrolling. This would also suggest that data of some kind is being sent wireless over the dongle.. but why does it not display "hello" in the ascii dump
    Jan 2013
    Texas USA
    Default Re: Serial over Blue Tooth
    Swampy,
    Isn't the default baud rate for the HC-06 9600?
    If so, try setting the HSER port baud rate on the PIC in PBP to 9600.
    TABSoft
    Oct 2009
    Swampy ??? SWampy !! - actually I quite like that for a user name
    Doh ! Re-compiled with settings for 9600 (need more sleep !!), didn't get "Hello", looks more like Klingon but had more bytes (80,98,9E,E0,FE,9E was the most common).
    Jan 2013
    Texas USA
    Sorry, autocorrect. :-0
    Can you setup your terminal program to receive in hex and capture the repeating string as received?
    TABSoft
    Jan 2013
    Texas USA
    For the 18F4580 @ 40MHz you have several options for 9600. I would try option 1 with the best %error rate.
    1. Synch = 0, BRGH = 0, BRG16 = 1, SPBRG = 1040 (dec) 0.06% error rate
    2. Synch = 0, BRGH = 0, BRG16 = 0, SPBRG = 64 (dec) 0.16% error rate
    3. Synch = 0, BRGH = 1, BRG16 = 0, SPBRG = 25 (dec) 0.16% error rate
    4. Synch = 0, BRGH = 0, BRG16 = 1, SPBRG = 259 (dec) 0.16% error rate
    TABSoft
    Oct 2011
    East Coast USA
    Remember the hc-06 is a 3.3v device, so the pic has to be 3.3v or you need to convert levels.
    I found this website for some great info
    http://mcuoneclipse.com/2013/06/19/u...etooth-module/
    Here's an easy way to test your HC-06, and the comms with the host/client. Just short its Tx and Rx, power it up (3.3 or 5, depending on whether you have the bare version or the one on a backpane).
    Anything you type on your terminal should echo back whatever you type. A simple test, no pic involved, no baud rate issues.
    Incidentally, you could also test on an Android, instead of a Windows machine. There's a beautiful terminal emulator called Blueterm on the playstore.
    Anand
    Oct 2009
    Thanks guys for the inputs.
    I remember that I was playing with the AT commands and seems I set the baud rate to 38400 !! - I went through the process of changing baud rates in the windows driver and the software until it responded to the AT prompts with an OK. I then re-compiled the test code with the hardware settings for 38400 and once loaded connected via the terminal program --- bingo, or should that be "hello"
    I then changed the serial defines in my main code and have the PIC responding over BT when using the terminal program, IR send Q for queries and all the date for the current prob readings and setting are streamed to the PC. Only problem is that the PC app crashes and screws up the sub system so I need to restart the PC .
    Error log timestamp Monday 29/06/15 19:03:38
    Runtime error: Element not found.
    Error(Exception)>>defaultAction
    Error(Exception)>>activateHandler: <anUndefinedObject>
    Error(Exception)>>handle
    Error(Exception)>>signal
    Error class(Exception class)>>signal: <'Element not found.'>
    BasicRunProgram(Object)>>error: <'Element not found.'>
    BasicRunProgram(BasicProgram)>>terminateRun: <anError>
    [] in BasicProgram>>errorHandlerBlock
    ExceptionHandler>>evaluateResponseBlock: <aBlockClosure> for: <anError>
    [] in ExceptionHandler>>handle:
    ProtectedFrameMarker(BlockClosure)>>setUnwind: <aBlockClosure>
    BlockClosure>>invisibleEnsure: <aBlockClosure>
    ExceptionHandler>>handle: <anError>
    ExceptionHandler>>findHandler: <anError>
    Error(Exception)>>activateHandler: <anExceptionHandler>
    BasicRunProgram(BasicProgram)>>runError: <'Element not found.'>
    BasicRunProgram(BasicProgram)>>handleComError: <'Element not found.'>
    SerialDevice32(SerialDevice)>>error: <'Element not found.'>
    SerialDevice32>>openError: <1168>
    SerialDevice32(SerialDevice)>>open: <'COM4'>
    BasicCommStream>>from: <'COM4:115200,n,8,1,ds...'> mode: <'RANDOM'> handle: <'#1'>
    BasicRandomFile class(BasicFile class)>>from: <'COM4:115200,n,8,1,ds...'> mode: <'RANDOM'> handle: <'#1'> owner: <aBasicRunProgram> length: <128>
    [] in OpenCommand>>using:
    [] in BasicRunProgram>>begin
    ExceptionHandler>>evaluateProtectedBlock: <aBlockClosure>
    [] in ExceptionHandler>>activateDuring:
    ExceptionHandler>>activateDuring: <aBlockClosure>
    ExceptionHandler class>>handle: <anError class> with: <aBlockClosure> during: <aBlockClosure>
    BlockClosure>>on: <anError class> do: <aBlockClosure>
    BasicRunProgram(BasicProgram)>>gotoAndIfStoppedBegin: <'[IoWait]'>
    BasicRunProgram(BasicProgram)>>handlerName: <'[IoWait]'> evaluate: <aBlockClosure> callParameters: <anOrderedCollection>
    BasicRunProgram>>handlerName: <'[IoWait]'> evaluate: <aBlockClosure> callParameters: <anOrderedCollection>
    BasicRunProgram(BasicProgram)>>submitHandlerName: <'[IoWait]'> evaluate: <aBlockClosure> callParameters: <anOrderedCollection>
    BasicRunProgram(BasicProgram)>>submitHandlerName: <'[IoWait]'> callParameters: <anOrderedCollection>
    TimerTopPane>>wmTimer: <333598> with: <0>
    TimerTopPane(Object)>>perform: <#wmTimer:with:> with: <333598> with: <0>
    NotificationManager>>notify: <aWinMessage>
    NotificationManager>>notifyRecursive
    NotificationManager>>recursiveMessage
    SystemDictionary>>recursiveMessage
    SystemDictionary>>launch
    The error message is stated above, and there are references to 115200 baud, but I've tried running the application from within the KDE and it still errors. My guessing is that it's something to do with the port handling in Liberty Basic as it works fine with real RS232 connection and when I use a couple of FTDI USB to serial boards, being direct connections. Although the BT dongle produces a virtual com port and this is detected by the initial windows that scans for open ports, it fails to detect the controller (sends out "C" and expects "R" in return) and then crashes and has to be end tasked. At this point the BT pairing drops and wont re-connect and the PC has to be re-booted with both dongles powered down at the time.
    FOR TempWD = 0 TO 1000
        IF RCIF=1 THEN GOSUB coms                   ; Check to see id PC application connected
        PAUSE 1
    NEXT TempWD
    This section above checks the buffer to see if something is deposited into it (so I was told)
     coms:
    HSERIN [nTest]
        SELECT CASE nTest
        CASE "C"                    ; if C then application checking for controller
        goto respond
        CASE "Q"                    ; if Q then send data to PC
        Goto Term_TX
        CASE "S"                    ; if S then receive data from PC
        goto Term_RX
    respond:
    Hserout ["R"]
    then the coms section responds, and initially sends data to the PC and then waits for the next "Q"ueriy or receipt of updated data "S"ent from the PC application.
  1. Blue Tooth Modules
    By Gord11 in forum mel PIC BASIC Pro
    Last Post: - 11th August 2011, 19:10
  2. RS232 to blue tooth modules
    By isaac in forum Bluetooth
    Last Post: - 14th March 2008, 13:00
  3. Killing blue led's
    By Steve_88 in forum Off Topic
    Last Post: - 31st January 2008, 02:37
  4. 16x2 lcd with blue backlight selling
    By macx75 in forum Adverts
    Last Post: - 8th May 2006, 07:12
