16f690 doesn't work with second Page
Results 1 to 4 of 4
    Jun 2015
    Default 16f690 doesn't work with second Page
    Hi community,
    I have a problem with my PIC 16F690. My program is now 2000 lines tall, and now I must use the second page. Normally it shout be no problem, but in my case it is.
    The problem is that if I programming my pic with the source code form the MPLAB then the Pic doesn't work correctly. In the debugger of MPLAB it works correct.
    I specify the second page at the program memory (org 0x800). When I'm looking in the listingfile, then i see that the source code of the second page is located at 0x800 forward.
    Has someone a idea why it doesn't work in the physical Pic but in the debugger? or what is may mistake ?
    cheers
    Default Re: 16f690 doesn't work with second Page
    I have scanned very quickly ! the data sheet and done a Google (Piclist), are you setting the registers needed to point to page 2 directly before you do a call to code there, and presumably, vice versa when going back to page 1. Some of your code would be helpful.
    PBP takes care of paging ...
    soooo, may be wrong forum for this kind of behaviour ???
    Jun 2015
    Hi Guys thanks for the response!
    befor I change to another page I do pagesel "name of function" (page 2) and after a return I do an pagesel to page 1. At the end of page 1 i declare with org 0x800 the program memory for the second page.
    org 0x800
    #include <Main_Init.inc>
    Everything after this lines is on the second page, right ? So all program code which is called will be called with pagesel, alternative with lcall.
    That is an example for a call to the second page.
    pagesel Init_ALL
    lcall Init_ALL ; initialized all important registers
    pagesel $
    What is wrong on my version ??
  1. get a sensor digital input to work on a pickit 2 16f690 lpc
    By Jasonstew in forum mel PIC BASIC Pro
    Last Post: - 26th June 2011, 21:26
  2. confuse page write??
    By MINHLE in forum General
    Last Post: - 22nd April 2010, 11:20
  3. Darrel's page is out
    By MarioC in forum General
    Last Post: - 14th August 2008, 07:34
  4. clockx.bas in samples page,can work good with the 16f84a?
    By lutherblissett in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2005, 12:09
  5. Page boundaries
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 16th August 2004, 17:36
