Need help converting a 4 bit binary number to 4 separate values
Results 1 to 4 of 4
    Oct 2009
    Utah, USA
    Default Need help converting a 4 bit binary number to 4 separate values
    Hey group,
    I am trying to build a Decimal / Hex / Binary number demonstrator to teach electronics and microcontrollers to a bunch of Scouts (the Electronics merit badge is what I am teaching)
    I am stuck on the following problem... (and running out of time before the upcoming class)
    If I have a number x (from 0 to 15)
    I need to set variables d,c,b,a to the binary representation of the 4 digit positions of x.
    so if x = 8 which is %1000 in binary
    then...
    a should =0
    b should =0
    c should =0
    d should =1
    so if x = 9 which is %1000 in binary
    then...
    a should =1
    b should =0
    c should =0
    d should =1
    I have tried (with no success) many different methods including arraywrite and bin string modifiers but they are all failing.
    I have tried a 4 byte array
    I have tried trying to select each digit in the 4 bit binary number
    I know there is a way I just can't get to it (yet)
    My final purpose is to write each of the 4 digit positions to a I2C 4-digit 7-segment display, I need to be able to write each digit to its position 0-3 separately.
    Any Ideas or guidance would be greatly appreciated.
    My code is just a mess right now
    here is a NON WORKING partial
            i2cwrite sda,scl,$e0,0,[bin1 x]
            i2cwrite sda,scl,$e0,1,[b]
            i2cwrite sda,scl,$e0,2,[c]
            i2cwrite sda,scl,$e0,3,[d]
    How do I select a given digit from within a 4 bit number and send just that digit to the I2C display??
    I guess I may have to resort to some sort of look up table for each of the 4 digit positions.
    thanks
    Dwight
    Oct 2009
    Utah, USA
    Default Re: Need help converting a 4 bit binary number to 4 separate values
    This is working, not very elegant but, hey, its working.
    Now to figure out how to do it for 8 bits by dividing the "Counter" down to get the second upper 4 bits.
    '=======  SubRoutine to write to the 7 Seg Binary display   ==========
    Binary:
    for z=0 to 3   'character position
        lookup z,[0,2,6,8],chrpos    ' value used to tell the I2C display which digit
        SELECT CASE counter
            case 0 :LOOKUP z, [$3f,$3f,$3f,$3f], chrdsp  '0000
            Case 1 :LOOKUP z, [$3f,$3f,$3f,$06], chrdsp  '0001
            Case 2 :LOOKUP z, [$3f,$3f,$06,$3f], chrdsp  '0010
            Case 3 :LOOKUP z, [$3f,$3f,$06,$06], chrdsp  '0011
            Case 4 :LOOKUP z, [$3f,$06,$3f,$3f], chrdsp  '0100
            Case 5 :LOOKUP z, [$3f,$06,$3f,$06], chrdsp  '0101
            Case 6 :LOOKUP z, [$3f,$06,$06,$3f], chrdsp  '0110
            Case 7 :LOOKUP z, [$3f,$06,$06,$06], chrdsp  '0111
            Case 8 :LOOKUP z, [$06,$3f,$3f,$3f], chrdsp  '1000
            Case 9 :LOOKUP z, [$06,$3f,$3f,$06], chrdsp  '1001
            Case 10 :LOOKUP z, [$06,$3f,$06,$3f], chrdsp '1010
            Case 11 :LOOKUP z, [$06,$3f,$06,$06], chrdsp '1011
            Case 12 :LOOKUP z, [$06,$06,$3f,$3f], chrdsp '1100
            Case 13 :LOOKUP z, [$06,$06,$3f,$06], chrdsp '1101
            Case 14 :LOOKUP z, [$06,$06,$06,$3f], chrdsp '1110
            Case 15 :LOOKUP z, [$06,$06,$06,$06], chrdsp '1111
        end select
        I2cwrite sda,scl,bin00,chrpos,[chrdsp]
    next z
    The $3F represents a "0" and $06 is for a "1"
    What I am using is this 7-Segment 4-digit display from Adafruit.
    https://www.adafruit.com/product/880
    They have some sample code but it's for an Arduino.
    "No I will not give up my PICBasic!!!"
    Dwight
    Here's a couple of ideas:
    Value VAR BYTE
    A VAR Value.0
    B VAR Value.1
    C VAR Value.2
    D VAR Value.3
    A,B,C,D will then be treated as BIT variables which may or may not work for your intended purposes. If it doesn't then perhaps:
    Value VAR BYTE
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    D VAR BYTE
    Convert:
      A = (Value & %00000001)                     ' A will be either 0 or 1
      B = (Value & %00000010) >> 1
      C = (Value & %00000100) >> 2
      D = (Value & %00001000) >> 3
    If you're writing to a display and what it's actually looking for is the ASCII representation of the numerical digit '1' (instead of the binary value 1) then just add 48 to the value:
    Convert:
      A = (Value & %00000001) + 48              ' A will be either 48 ('0') or 49 ('1')
      B = ((Value & %00000010) >> 1) + 48
      C = ((Value & %00000100) >> 2) + 48
      D = ((Value & %00001000) >> 3) + 48
    Oct 2009
    Utah, USA
    Thanks Henrik,
    I'll give those a try.
    When I get this working it will have...
    • 8 digit 7-segment display of 8 bit binary number in the form of 1's and 0's
    • 8 individual LED's to represent an 8 bit binary number in the form of High and LOW (on/off)
    • 2 digit alphanumeric display to represent Hex number
    • 4x20 LCD using BIG digits to display Decimal number
    All controlled by a 16F690.
    Will count up/down from 0-255
    Each of the above listed display formats will show the same number in a different way.
    A POT will increase/decrease/stop counting speed
    2 buttons to change counting direction or single count when pot is turned all the way to stop.
    My intention is to have a way to show the same number in DEC / HEX / BIN so that students can see the relationship between the different number formats.
    Oh Yeah, and to have something sort of Rube Goldberg-ish and kind of geeky to spark interest in electronics and programming.
    I'll try and post the code and a video when I get it finished.
    thanks
    Dwight
  1. Replies: 10
    Last Post: - 8th March 2015, 20:26
  2. Changing output binary number sequence? is it possible?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2013, 01:47
  3. Replies: 7
    Last Post: - 11th September 2010, 01:32
  4. Convert long binary number to ASCII Decimal
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 9th July 2009, 14:58
  5. Averaging 16 bit values without using 32 bit math
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 5th October 2007, 23:18
