A tft addin for pbp3
Results 1 to 40 of 142
    Jun 2005
    West Australia
    Default Re: A tft addin for pbp3
    Hi Richard,
    Thanks for being there . Yes I think so too but don't know how to enforce the borders. I'm really interested in using Portrait mode too to make text legible in a skinny rail mounted enclosure.
    @Ioannis
    It's Richard's hard work not mine, he deserves the congrats. Below is the code configured for the ST7735 and the Includes/files are the latest I could find in the thread.
    Any help or suggestions appreciated.
    Kind regards,
    Bill
    '*  Name    : pic18f2520_tft_demo.pbp              #### semi-Working Code #### *  but not pretty, needs lots of work.
    '*  Author  : RICHAED                                                       *
    '*  Notice  : Copyright (c) 2015                                            *
    '*          : All Rights Reserved                                           *
    '*  Date    : 12/09/2015                                                    *
    '*  Device  : 18F2520 (32k)                                                 *
    '*  Version : ?     25295  bytes (PBP 3.1.4.4)                              *
    '*  Notes   : sleep, pwm brightness (10 bit pwm)                            *
    '*          : new way to define tft pins                                    *
    '*          :  24 BIT ADDRESS FOR STRINGS AND BUTTON TEXT                   *
    '*          : See: www.picbasic.co.uk/forum/showthread.php?t=20115          *
    '*  ======> : 3v3 screen! Draws ~ 80mA.                                     *
    '*          : TFT ILI9431 works okay but not pretty, needs lots of work.    *
    '*          : ST7735 (KMR-1.8" and Touch version each 128x160) work but the *
    '*          : code needs fix - only 1/4 of TFT size screen shown instead of *
    '*          : a reduced scale version to fit into 128x160 frame.            *
    '*          : #### How to put into Portrait mode? ####                      *
    ; 07Feb22 Huge trawling exercise to sort the many variations of this evolution on the Forum.
    ;         Includes are the last/latest versions found in the thread (could this be the problem?).
    ;         Testing with 2.4" 240x320 TFT is functional using ILI9431 and also ST7735 (1.8" 128x160).
    ;         Had some frustrating moments programming this, MeLabs usb changed for PicKit3 confirmed it
    ;         was the problem, using Test 18f2520.pbp code also proved it.
      CONFIG  OSC = INTIO67
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 3
      CONFIG  WDT = OFF
      CONFIG  WDTPS = 512
      CONFIG  CCP2MX = PORTC
      CONFIG  PBADEN = OFF
      CONFIG  LPT1OSC = OFF
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    ; TFT in landscape has conn LHS, KMR RHS, 1.8 Touch RHS
    ; TFT in portrait has conn ?, KMR ?, 1.8 Touch ?
    ;                                               Led- Gnd    2x8 pin hdr
    '    PIC(18F2520)           OTHER               KMR-1.8"    1.8" Touch
    ' MCLR PortE.3 (pin 1)      Pull High 10k.
    ' C1-  PortA.0 (pin 2)
    '      PortA.1 (pin 3)
    ' C1+  PortA.2 (pin 4)
    '      PortA.3 (pin 5)
    ' C1OP PortA.4 (pin 6)      T_DIN Pin TFT.      nc
    '      PortA.5 (pin 7)
    '      Ground  (pin 8)
    '      PortA.7 (pin 9)      T_CLK Pin TFT.
    '      PortA.6 (pin 10)     T_DO Pin TFT.                   not tested XPT2046 chip
    '      PortC.0 (pin 11)
    ' CCP2 PortC.1 (pin 12)     9600 True via 1k.
    ' CCP1 PortC.2 (pin 13)     BL drive-1k-PNP.    Led+        BLK(7) Led A already to +, rejig PNP to switch ground.
    '  SCL PortC.3 (pin 14)     SCK Pin TFT.        SCL         CLK(3)
    '  SDA PortC.4 (pin 15)
    '  SDO PortC.5 (pin 16)     SDI(MOSI)Pin TFT.   SDA         MOS(4)
    '  Tx  PortC.6 (pin 17)
    '  Rx  PortC.7 (pin 18)
    '      Ground  (pin 19)     Gnd                 Gnd         Gnd(1)
    '      +Supply (pin 20)     +3v3                +3v3        +3v3(2)
    ' INT0 PortB.0 (pin 21)     T_IRQ Pin TFT.
    '      PortB.1 (pin 22)
    '      PortB.2 (pin 23)     T_CS Pin TFT.
    '      PortB.3 (pin 24)     DC Pin TFT.         A0          DC(6)
    '      PortB.4 (pin 25)     RESET Pin TFT.      RESET       RES(5)
    ' T1G  PortB.5 (pin 26)     CS Pin TFT.         CS          CS1(9), CS2(10) works w/o either????
    ' PGD  PortB.6 (pin 27)
    ' PGC  PortB.7 (pin 28)
    DEFINE NO_CLRWDT 1
    #DEFINE TOUCH_SCREEN 1
    #DEFine  dbug 1             ; Comment if not req'd.
     ;-----------connection----------
    ;        pic                     tft
    ; <tft_port.tft_dc_bit >-------< dc   >
    ; <tft_port.tft_cs_bit >-------< cs   >
    ; <tft_port.tft_rst_bit>-------< rst  >
    ; <msspx.sdo >-----------------< mosi >
    ; <msspx.sck >-----------------< sck  >
    ; <back_light>-----------------< led  >   via pnp cct
    ;*****************NEW EASY PIN DEFINES*********************************
        tft_dc_bit  con 3       ;ie bit 3
        tft_cs_bit  con 5       ;ie bit 5
        tft_rst_bit con 4       ;ie bit 4
        tft_port   var latb
        back_light var latc.2   ; portc.2
        cont       var word     ; backlight level
    ;    WIDTH    con  320   ; X   MUST MATCH TFT MODULE
    ;    HEIGHT   con  240   ; Y
        WIDTH    con  160  ; X
        HEIGHT   con  128  ; Y
    ' my TOUCH_SCREEN connection definitions
     T_CLK    VAR   PORTa.7
     T_INPin  VAR   PORTa.4
     T_OUTPin VAR   PORTa.6
     T_INT    VAR   PORTb.0
     T_CS     VAR   LATb.2
     number_of_buttons con 6
     number_of_sliders con 1
            INCLUDE "TFT_SPI.pbpmod"        ;glcdc
    ;        include "tft-ILI9431.bas"
            include "tft-ST7735.bas"
            INCLUDE "DT_INTS-18.bas"
            INCLUDE "ReEnterPBP-18.bas"
            INCLUDE "my_Elapsed_INT-18.bas"
            include "TOUCH_TFT.PBPMOD"      ;uncomment  to use TOUCH_TFT
            INCLUDE "font7x8.bas"
     goto demostart
     upbutton:
     @ db 131,0              ; chr 131 is AN up arrow in this font THAT I'M USING
    demostart:
    INT_LIST  macro    ; IntSource,        Label,           Type,   ResetFlag?
            INT_Handler   TMR1_INT,   _ClockCount,      PBP,  yes
        INT_CREATE
    @ INT_ENABLE  TMR1_INT
        led_on var bit
        led_on_time var word
        time_now var word
        BOXX VAR  BYTE
        BOXY VAR  BYTE
        BOXZ VAR  BYTE
        cnt var byte
        clear
    '    latb=255   ;  make sure tft etc are not selected ie all cs high *************NOW IN TFT INIT********************
        TRISA=%00111111
        TRISB=%11000011
        TRISC=%11010011
        ADCON0 = 0              ' Disable A/D.
        ADCON1 = %00000110      ' All digital.
        OSCCON = %01110000 		' Internal 8 Mhz Osc
        OSCTUNE=%01000000		' PLL ON
        cont=500                ; half brightness
        DEFINE OSC 32
        buff var byte[32]
        t2con=5
        PR2 = 255;
        CCPR1L = cont>>2;             ;set pwm
        ccp1con=12|((cont&3)<<4);
        SSPCON1=$20  ;$20-21-22 works 20 IS FASTEST
        SSPSTAT=$40
        TEXTSIZE=2
        gosub tft_init
        gosub TOUCH_INIT
        GOSUB ResetTime
        GOSUB StartTimer
    '    #ifdef dbug
    '    trisb.7=0    ;DEBUG OUT
    '    latb.7=1
    '    pause 4000
    '    Serout2 PORTb.7,84,["ready ", 13,10]
    '    #ENDIF
        #ifdef dbug
        trisc.1=0    ; DEBUG OUT
    ;    latc.1=1     ; Float high for True.
        latc.1=0     ; Float low for Inverted. The Nortek white usb serial adapter used here.
        pause 4000
    ;    Serout2 PORTc.1,84,["ready True ", 13,10]
        Serout2 PORTc.1,16468,["ready Inverted ", 13,10]
        #ENDIF
        glcdc  font7x8       ;SET FONT
        bg=$ffff
        fg=0
        fillrect 0,0,WIDTH,height    ;cls
        TEXTSIZE=4
        GLCDc 50,103
        GLCDC   "READY"
        pause 400
        bg=$ffff
        fg=0
        MAKEBUTTON 53,170,0,92 ,40,"Clear" ;
        MAKEBUTTON  276,220,1,56,30,"Sleep"
        MAKEBUTTON  280,150,2,60,"Led"
        MAKEBUTTON  242,52,3,40  ; no  text  SEE BELOW   FOR Another way to attach text
        MAKEBUTTON  140,150,4,50,30," +"
        MAKEBUTTON  205,150,5,50,30," -"
        button_action.0[1]=1  ; flash text for this button
        button_action.0[2]=1  ; flash text for this button
        button_rpt.0[4]=1    ;   auto rpt on button 4
        button_rpt.0[5]=1    ;   auto rpt on button 5
        ;another way to attach text to a button   [HANDY FOR CHRS NOT IN ASCII 7 BIT PRINTABLE RANGE] EG THERE IS NO OTHER WAY TO GET CHR 131 IN A PBP STRING
    @ GetAddress21 _upbutton ,_tft_bigaddress  ;macro in dt_ints-18
        button_Taddr[3*3]  = tft_bigaddress[2]
        button_Taddr[3*3+1]= tft_bigaddress[1]  ;assign a new text to button 3
        button_Taddr[3*3+2]= tft_bigaddress[0]
        button_Tsize[3] =1  ;UPDATE  NUMBER OF text CHRS for this button
        MAKESLIDER 100,80,0
        slider_index  =0
        the_slider = slider_index *SL_SZ  ; set slider indexing properly
        slider_FG[the_slider ]=$ffe0    ;set slider bar colour if default not desired
        slider_count[the_slider]=cont/10
        bg=0
        INTCON2.6=0
        led_on=0
        fg=$7FF
        DRAWBUTTON  0
        DRAWBUTTON  1
        DRAWBUTTON  2
        DRAWBUTTON  3
        DRAWBUTTON  4
        DRAWBUTTON  5
        slider_index  =0
        slider_MODE[the_slider]=0    ;FORCE DRAW OF SLIDER
        DRAWSLIDER  0
        fg=$ffFF
         DRAWcircle  60 , 60 , 20
         fillcircle  60 , 60 , 20
    LOP:
        GOSUB  CK_BUTTON
        IF      BUTTON_STATE[0]==2   THEN
            BUTTON_STATE[0]=0
            fg=0
        elseIF      BUTTON_STATE[1]    THEN
            if BUTTON_STATE[1]==2 then     ; shut it all down
                gosub tft_sleep
                 ccp1con=0
                 back_light=1
                 intcon=$10
                 @ sleep
                 @ nop
                 intcon=$c0
                 gosub tft_wake
                 CCPR1L = cont>>2;
              BUTTON_STATE[1]=0
        elseIF  BUTTON_STATE[2]     THEN   ;short or long press
                drawimage 220,30,45,45,led
                led_on=1
                gosub get_now
                led_on_time=time_now
                BUTTON_STATE[2]=0
        elseIF  BUTTON_STATE[3]     THEN
                if BUTTON_STATE[3]==2 then
                    DRAWBUTTON  3
                 fg=0
                fillrect 220,30,45,45
               drawimage 220,30,45,45,led2
                BUTTON_STATE[3]=0
        elseIF  BUTTON_STATE[4]    THEN   ; short , long press  or RPT
                CNT=CNT+1
                 BUTTON_STATE[4]=0
                 gosub s_cont
        elseIF  BUTTON_STATE[5]     THEN   ; short , long press or RPT
                 CNT=CNT-1
                  BUTTON_STATE[5]=0
                  gosub s_cont
        slider_index  =0
        IF   slider_MODE[the_slider]&1 THEN         ; adjust brightness
            gosub set_cont
        if led_on then
            gosub get_now
            if abs(time_now-led_on_time) > 100 then
             DRAWBUTTON  3
            fg=0
    '        fillrect 220,30,45,45
    '       drawimage 220,30,45,45,led2
             led_on=0
        if    SecondsChanged  then
            fg=$F800
            bg=$ffff
            SecondsChanged=0
            TEXTSIZE=2
            BOXX=6*7*TEXTSIZE
            BOXY=HEIGHT-(TEXTSIZE*8+1)
            ARRAYWRITE buff,[dec2 seconds,0]
            GLCDSTR BOXX,BOXY ,buff
        if    hoursChanged  then
            hoursChanged=0
            TEXTSIZE=2
            ARRAYWRITE buff,[dec2 hours,0]
            GLCDSTR 1,BOXY ,buff
        if    minutesChanged  then
            TEXTSIZE=2
            minutesChanged=0
            BOXX=3*7*TEXTSIZE
            ARRAYWRITE buff,[dec2 minutes,0]
            GLCDSTR BOXX,BOXY,buff
     goto LOP
     set_cont:
            cont = 1000 - slider_COUNT[0]*10
            CCPR1L = cont>>2;
            slider_MODE[the_slider]=slider_MODE[the_slider]&$FE
            cnt=  slider_COUNT[the_slider]
       s_cont:
            TEXTSIZE=3
            bg=0
            fg=$7FF
            ARRAYWRITE buff,[dec3 cnt,0]
            GLCDSTR 50,10 ,buff
     get_now :
    @ INT_DISABLE  TMR1_INT    ;disable int to get  value of ticks WITHOUT ROLLOVER ISSUES   [TICKS IS NOT ATOMIC]
     time_now=ticks           ; 1 tick==10mS
       #ifdef dbug
    db_prn:
    intcon.7=0
        Serout2 PORTb.7,84,["t ",#TU_TMP3 , 13,10]
    intcon.7=1
        #ENDIF
    INCLUDE "led2.bas"
    INCLUDE "led.bas"
    most of the addin's have user-commands. in the include file where the commands are declared there are comments on how to use them
    eg in touch_tft
    ;work around fact that  usercommand won't accept a 1 chr string (thinks its a const)  so leading space is ignored  in button title
        USERCOMMAND "DRAWBUTTON"    ; BTN    { BUTTON NUMBER }
        USERCOMMAND "MAKEBUTTON"    ; X,Y ,BTN,{w},{h} ,"title" [(XY IS button centre)  BUTTON  number  ,   BUTTON size  WILL BE default_button_size IF SIZE OMITTED h=w if h omitted]
        USERCOMMAND "DRAWSLIDER"    ; SLIDER    { SLIDER NUMBER  }
        USERCOMMAND "MAKESLIDER"    ; X,Y {W,H},SLIDER   [(XY IS LHBottom CNR ) SLIDER number    size  WILL BE default  IF W,H OMITTED
    x, y are cartesian coordinates for the screen position of the desired object , it goes without saying that x is horizontal axis [width] y vertical axis [height] when facing screen. both x and y need to be on the screen, objects can also have a width [w] and a height [h] and it follows that
    x+w should still be on the screen as well as with y+h
    if your objects don't fit on the screen then things won't play nice
    start here
    which of these fit on a screen 160x128 ?
    answer none
    and so on
    in chipset driver file you will find this
         ;SCREEN ORIENTATION
        TFTDATA $18       ;bit3 controls rgb/bgr  0=bgr , 1 =rgb
                          ;bit2 controls  refresh direction  long  axis
                          ;bit4 controls  refresh direction   short  axis
                          ;bit5 controls portrait/landscape   1=portrait , 0 =landscape  / adjust height width to suit
                          ;bit6 controls  write direction short axis
                          ;bit7 controls  write direction long  axis
    it needs to be setup to match your screen re-orientation and mirror imaging, its no big deal
    you need to set height/width declares to match
  1. Replies: 0
    Last Post: - 25th September 2013, 19:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 09:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 17:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 18:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 01:15
