A tft addin for pbp3
Results 1 to 40 of 142
    Oct 2013
    Default Re: A tft addin for pbp3
    I tried to test the repetitively button, it works but not as expected.
    When I touch the button the counter starts counting, and its value increases every 300ms for one and then suddenly accelerate and in few mS in increase his value very quikly and then slow down.
    If it happens to someone else or just me?
    Why you have selected BS250
    because it comes in a t092 package I can use in a breadboard for testing , yes a IRLML9301TRPbF would probably be better but they only come in a sot23 package.
    visnja30 repetitively button, it works but not as expected
    I would need to see your code to be sure ,button auto repeat works for me just fine . auto repeat won't begin until long_press_threshold has been reached and will repeat @ repeat_press_rate
    these constants in the TOUCH_TFT.PBPMOD file control button timing . they may need adjusting depending on OSC and "gosub CK_BUTTON " loop rate
    repeat_press_rate con 100 ;button auto repeat rate (must be less than long_press_threshold)
    long_press_threshold con 300 ; min time for a BUTTON long press result
    short_press_threshold con 20 ; min time for a BUTTON pressed result
    I put a bug in the CK_BUTTON: subroutine in the TOUCH_TFT.PBPMOD file , it stops a long_press being detected
    should be this
    IF button_count[the_button] >= long_press_threshold THEN
    instead of
    IF button_count[the_button] > long_press_threshold THEN
    I will post a amended version when I finish getting the >64k code location problem solved for strings
    some updates
    CK_BUTTON: subroutine in the TOUCH_TFT.PBPMOD file fixed
    const txt strings can now be anywhere in addressable pgm memory
    button txt strings can now be anywhere in addressable pgm memory
    pin definitions for tft dc/cs/rst have been simplified
    eg. for tft cs on bit 5 instead of tft_cs_bit con 32 is now
    tft_cs_bit  con 5
    some changes to the touch add in
    now ready for 16 buttons ,makebutton is optimised a bit better, bank 0 dependency relaxed
    finally worked out why fillcircle was so slooooow
    a much faster solution
    Oct 2013
    I include file flash_spi.pbpmod there is two labels with the same name FL_IMG: is it OK or one labels is too much?
  1. Replies: 0
    Last Post: - 25th September 2013, 18:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 08:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 00:15
