A tft addin for pbp3
Results 1 to 40 of 142
    Jan 2011
    Sydney, Australia
    Default Re: A tft addin for pbp3
    Hi Richard,
    I am having some issues compiling your TFT_Demo program and hope you can steer me in the right direction.
    I am using Microcode Studio 5.0.0 5 and PBPX 3.0.7.4
    When I first compile I get a "Syntax Error (195)". The line of code is "fillcircle 60 , 60 , 20"
    I have looked through the include files and cannot find a USERCOMMAND for "fillcircle". What am I missing?
    Attempting to move on, I commented out the offending fillcircle line of code and tried to compile again.
    Now I get four ASM ERROR message "Address label duplication or different in second pass".
    (Z001D9) (Z001DA) (Z001DB) (Z001DC)
    I am very keen to get my new TFT Touchscreen operational so any advice on how to correct the above issues would be greatly appreciated.
    I have attached all relevant files (main program, includes etc.) for your reference.
    Cheers
    Barry
    VK2XBP
    hi barry
    the address dup messages come from having coff file generation turned on when using dt_ints , don't know why ,wish it wouldn't
    see the attached screen shot to remedy that
    the syntax error i think comes from not using the latest tft-spi.pbpmod file
    I have uploaded the latest just incase I stuffed up
    I did stuff up , seems I forgot to upload the latest version with fillcircle command in it .
    apologies to all,
    Jan 2011
    Sydney, Australia
    Thanks Richard - that did the trick!
    Everything compiles and programs.
    Now to breadboard it and make it work
    Cheers
    Barry
    VK2XBP
    Jan 2011
    Sydney, Australia
    Hi Richard,
    I have had a small amount of success getting this thing going but still having a few problems.
    Firstly, your .pdf circuit diagram appears to have another mistake (apart from the MCLR issue)
    You show the LED connection on J2 as being Pin 9 however I believe it should be Pin 8 - or at least that's what is printed on the PCB silkscreen.
    I made the necessary adjustments but still nothing. I am getting a nice 50% duty cycle PWM signal (~7.8kHz) on CCP1.
    In frustration I connected the LED connection (J2 Pin 8) to the wiper of a 10k pot and adjusted it between 0V and 3.3V.
    Once I got to around 3V the screen came to life - or at least half of it did
    I think I might have a dodgy TFT screen.
    I can see the elapsed timer counting and some of the reset button but most of the right side of the screen is scrambled with a big black ovoid shape in the middle.
    Looks like I need to do another eBay purchase but don't really want to have to wait 3-4 weeks for it to arrive!
    Thanks for all your help thus far. I will be in touch again once I have a new screen to play with.
    Cheers
    Barry
    VK2XBP
    your right about the schematic I have uploaded a correct version , I have replaced the transistor with a pch mosfet (saves two resistors) but it still loses a little brightness and is no better than the transistor version
    I had similar issues with mine , turns out the sil connector was very poorly soldered a bit of rework fixed it
    Dec 2007
    Finland
    Thanks for the schematic update. Now I have to start gathering all needed components.
    Why you have selected BS250, which has quite huge Rds(on), it is round 10 Ohm or more @3.3V. Why not go with a good PFET like IRLML9301TRPbF, which has ~100-200mOhm Rds(on) @3.3V. Also price is half of the BS250. With this FET you will not burn energy in transistor -> LED will be brighter.
  1. Replies: 0
    Last Post: - 25th September 2013, 18:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 08:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 00:15
