A tft addin for pbp3
Results 1 to 40 of 142
    Default Re: A tft addin for pbp3
    On which the port and pin I connects serial communication between PC and PIC
    I have used rx2/tx2 (the code could be altered to use tx1/rx1)
    What is the maximum number of buttons possible to make the TFT screen.
    this is the limiting factor
    button_flg VAR BYTE ;1 BIT PER BUTTON make it a word to have up to 16 buttons
    I tried to make a four keys and the fourth button is not working. The first three are working.
    button state is not defined when buttons are created easiest solution is to insert a clear command
            INCLUDE "TFT_SPI.pbpmod"        ;glcdc
            include "tft-ILI9431.bas"
            'INCLUDE "flash_spi.pbpmod"
            include "TOUCH_TFT.PBPMOD"      ;uncomment  to use TOUCH_TFT
            INCLUDE "font7x8.bas"
        latb=255   ;  make sure tft etc are not selected ie all cs high
        TRISA=111111
        TRISB=000011
        TRISC=010011
        TRISD=000000
        PORTD=0000000
        OSCCON = 110000         'Internal 8 Mhz Osc
        OSCTUNE=000000        'PLL ON
       clear
        cont=500               ;half brightness
        DEFINE OSC 32
        buff var byte[32]
        t2con=5
        PR2 = 255;
        CCPR1L = cont>>2;             ;set pwm
        ccp1con=12|((cont&3)<<4);
        SSPCON1=$20  ;$20-21-22 works 20 IS FASTEST
    how I can change color of screen wallpaper from black to yellow
    the screen colour has two properties fg (foreground) bg (background)
    set them as you like
    use fg=bg and fillrect to clear an area
    how I can changes color of buttons from red to green and how to change color of outline on buttons
    button_scheme var word[4] ; [background,text,border,animated (background or border) ]
    defaults
    button_scheme[0]= $1f
    button_scheme[1]= $0
    button_scheme[2]= $7ff
    button_scheme[3]= $ffff
    buttons can have different animations too
    button_action.0[1]=1 ;flash text for this button1
    button_action.0[2]=0 ;flash outline for this button2 ; default action
    Oct 2013
    Why I can not write lovercase letters only capital letters work?When I write lovercase letter I got only a bad piksel on screen.
    Buttons now work excellent.
    are you using the font that has lowercase chars in it ?
    the first font has chr 32 to 90 post#54
    the second has chr 32 to 127 post#67
    Oct 2013
    Yes,wrong include I use,now it is work.
    I create a counter,and when I touch the button counter increase e his value for 1.Each press increase counter for 1.
    COUNTER=COUNTER+1
    Is it possible to make that when i press a button and hold pressed the counter increase his value throughout the whole period when it pressed
    yes good idea , I have added an auto repeat property to buttons
      button_rpt.0[3]=1             ;button3 auto rpt
    Jan 2011
    Sydney, Australia
    Hi Richard,
    I am having some issues compiling your TFT_Demo program and hope you can steer me in the right direction.
    I am using Microcode Studio 5.0.0 5 and PBPX 3.0.7.4
    When I first compile I get a "Syntax Error (195)". The line of code is "fillcircle 60 , 60 , 20"
    I have looked through the include files and cannot find a USERCOMMAND for "fillcircle". What am I missing?
    Attempting to move on, I commented out the offending fillcircle line of code and tried to compile again.
    Now I get four ASM ERROR message "Address label duplication or different in second pass".
    (Z001D9) (Z001DA) (Z001DB) (Z001DC)
    I am very keen to get my new TFT Touchscreen operational so any advice on how to correct the above issues would be greatly appreciated.
    I have attached all relevant files (main program, includes etc.) for your reference.
    Cheers
    Barry
    VK2XBP
    hi barry
    the address dup messages come from having coff file generation turned on when using dt_ints , don't know why ,wish it wouldn't
    see the attached screen shot to remedy that
    the syntax error i think comes from not using the latest tft-spi.pbpmod file
    I have uploaded the latest just incase I stuffed up
  1. Replies: 0
    Last Post: - 25th September 2013, 18:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 08:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 00:15
