A tft addin for pbp3
Results 1 to 40 of 142
    Default Re: A tft addin for pbp3
    henrik
    I think your right and what you suggest may be as good as it gets
    add SSPBUF VAR SSP1BUF on Expression error
    WILL call this version 1.0 , the python code now converts the pixels to suit (saves the pic18 from all that work)
    the usercommand file has a more meaningful name but I forgot to update the demo's include to the new name
    change glcd_chr include to INCLUDE "TFT_SPI.pbpmod" ;glcdc
    Jan 2013
    Texas USA
    Richard,
    Great amount of work on this library.
    I have to hand it to you, a lot of coding you worked out there.
    For my own edification, I have a question for you.
    In "TFT_SPI.PBPMOD" you have your setxy 8-element byte array for y0, y1, x0 & x1 declared.
    This I understand.
    You do this to support Word variables for x0 & x1 and space for y0 and y1 to be used as Word variables in the future,
    but used as byte variables today. This I assume as the TFT display's y axis in less than 255.
    One thing I notice though is that you have the following ASM address mapping for the individual x&y elements.
    y0 = _setxy +1
    y1 = _setxy +3
    x0 = _setxy +4
    x1 = _setxy +6
    Then you have the following PBP variable declarations.
    x0 var WORD EXT
    x1 var WORD EXT
    y0 var byte EXT
    y1 var byte EXT
    Understood at this point.
    x vars are Words and y vars are Bytes.
    But here is my question, I thought I noticed you use a lot of manual (CHK?RP/movlw/movwf) manipulation within the USERCOMMANDS for
    the y0 & y1 variables instead of using PBP standard macros for MOVE?xx.
    Could you not change the ASM address mapping for the y0 & y1 elements to use Little Endian style, instead of Big Endian, and then use the
    standard PBP macros (MOVE?BB, MOVE?CB, MOVE?WB)?
    Wouldn't that simplify the ASM in the USERCOMMAND macros?
    Doesn't the PBP standard MOVE?xx macros take care of the BankSel testing/switching and movement of the High and Low bytes for you?
    y0 = _setxy +0
    y1 = _setxy +2
    x0 = _setxy +4
    x1 = _setxy +6
    I may be off base, but was just curious.
    I didn't read through the entire "TFT_SPI.PBPMOD", to see if there was another reason you have y0 & y1 defined in ASM as Big Endian.
    TABSoft
    good catch tabsoft , I missed that when I changed the setxy method and never finished "cleaning up" . the two hardware includes have been fixed also (same error)
    y0,y1 are now words and usercommand macros are more consistent
    version 1.1 for these files (already)
    Oct 2013
    I download python 2.7.10 version for windows and when I run it I get some errors.
    When I open script FLASH.py and pres F5 button run module I got this message:
    Python 2.7.10 (default, May 23 2015, 09:40:32) [MSC v.1500 32 bit (Intel)] on win32
    Type "copyright", "credits" or "license()" for more information.
    >>> ================================ RESTART ================================
    Traceback (most recent call last):
    File "C:\Python27\flash.py.TXT", line 6, in <module>
    import serial
    ImportError: No module named serial
    as I said you need to install some python extensions too
    the serial module is pyserial
    http://www.lfd.uci.edu/~gohlke/pythonlibs/
    Oct 2013
    Because I'm not a good programmer there is a few things that are not clear to me.
    Where I can download the Arduino utft ImageConverter 565.exe.I found only a online converter on Rinky-Dink Electronics web page.
    What is the purpose of this file "flash.py.TXT" and where I must copied this file.
    When I get a image file from ImageConverter565 how I can send this file to external Flash memory w25q32.
    where can I get ImageConverter565
    to find the image converter just google arduino utft library
    I got mine from here
    http://www.rinkydinkelectronics.com/library.php?id=51
    download the utft.zip ,its in the utft/tools folder
    flash.py.TXT needs to be renamed to flash.py
    its a python 2.7 script . you will need to install python 2.7 on to your pc
    to be able to run it
    #flash.py extract
    import os
    import time
    from Tkinter import *
    import serial
    import glob
    ser=serial.Serial("com27",38400)
    ser.flush()
    ser.timeout=.005
    there are some python apps that mat need to be installed too see above (os,time,Tkinter,serial,glob) most come preinstalled
    the code also wants a serial port (or it will crash and burn) mine uses com27 you can edit file to suit your setup , whatever port you supply needs to exist and be available for python to use
    this code can either make a pbp.bas include image file or transfer the image directly to external Flash memory via the serial port when used with my flash add in
  1. Replies: 0
    Last Post: - 25th September 2013, 18:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 08:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 00:15
