First GetADC using DT_Analog.pbp incorrect measurement afterwards is good. Why?
Results 1 to 3 of 3
    Jul 2010
    Default First GetADC using DT_Analog.pbp incorrect measurement afterwards is good. Why?
    I am using Darrel Taylor's DT_Analog.pbp for taking analog measurements. Measurements are taken in a loop using GetADC.
    The first ADC measurement is always an incorrect value. After the first measurement, all consecutive measurements are correct.
    To get around this I do a single measurement first. Then I run my loop to take multiple measurements using GetADC. What is the reason the first measurement is always bad or incorrect?
    Your help is always greatly appreciated.
    Bryan
    Default Re: First GetADC using DT_Analog.pbp incorrect measurement afterwards is good. Why?
    Hard to comment without seeing any code.
    Does the PIC have time to stabilize before taking the first reading?
    What if you add a short PAUSE?
    Sep 2010
    Las Vegas, NV
    At least for the 12F683 it has a charge holding capacitor in the ADC circuit. The way I understand it that needs to be give the appropriate amount of time to charge fully before you take a reading. That time may change depending on which chip you're using.
    My guess is that Demons suggestion of a short pause would solve the problem. Or a counter that won't allow display until the appropriate time has elapsed. Either gives the ADC a chance to stabilize and provide the correct reading.
  1. Acquisition time in DT_Analog when oversampling?
    Last Post: - 12th April 2015, 21:52
  2. DT_Analog.pbp
    Last Post: - 30th January 2015, 04:42
  3. DT_Analog & 12F1822 internal voltage reference
    Last Post: - 11th February 2014, 17:24
  4. DT_Analog.pbp
    Last Post: - 21st November 2013, 21:05
  5. DT_Analog Module Works Great,But Why?
    By arniepj in forum mel PIC BASIC Pro
    Last Post: - 1st October 2012, 20:32
