pic 16f688
Results 1 to 14 of 14
Thread: pic 16f688
    Aug 2014
    CHICAGO
    Unhappy pic 16f688
    Hello every body: I just joint the forum. Switching now slowly over from Basic Stamp 2 to the pick micro. I have Basic pro Gold . I have programmed some 12f683 successful. However I started now with the pic 16f688 because I needed more I/O. And it has the same programming pin configuration then the 12f683 which fits my Omega prototyping board. My Problem is: Con fig file. Or addressing the pins correctly. Or both. Especial I don’t know if using eight. $00000000 is OK because it is not working. I understand port A and port B have only 6 Ports. This is my code: #CONFIG ifdef PM_USED device pic16F688, intrc_osc_noclkout, wdt_on, mclr_on, protect_off else __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF endif #ENDCONFIG ansel=0 'set i/o to digital cmcon0 = 7 'comparator off TRISC=%000001 ' set PortC RC5-RC1 to ‘outputs, RC0 input PORTC=%000010 ' Set PortC RC1 high to turn ‘on LED1 Main: ' *** Test the switch state *** if portC.0 = 0 then led2 'If switch is pressed then ‘jump to LED2 routine PortC.1 = 1 ' Turn LED1 on portC.2 = 0 ' Turn LED2 off goto Main ' Jump to the top of the main loop LED2: '*** Turn LED2 on *** portC.2 = 1 ' LED2 on portC.1 = 0 ' LED1 off goto Main ' Jump to the top of the main
    Jun 2009
    Sc*nthorpe, UK
    Default Re: pic 16f688
    Quote Originally Posted by MERLIM View Post
    This the way to display you code
    Start by adding a PAUSE 500 after you turn the LEDs on and off.
    Your LED is probably blinking faster than your eye can detect (or not leaving enough time for the LED to emit light).
    Symbols in PBP have meaning that may be different than other languages, I. E. "C" .
    % is used for binary, example %11111111 it does NOT use 0b00000000 or $00000000 as binary
    $ is used for HEX , example $FF
    This response is to your thread http://www.picbasic.co.uk/forum/showthread.php?t=19419
    Apr 2012
    Ptolemaida
    If you don't want your pick to reset turn off the watchdog timer from configuration bits
    __config_ wdt off
    One man's magic is ANOTHER man's engineering.
    Supernatural is a null word
    Apr 2012
    Ptolemaida
    If you don't want your pic to reset turn off the watchdog timer from configuration bits
    __config_ wdt off
    Aug 2014
    CHICAGO
    Thank you .
    Sorry, I was not working for a long time and newer answered.
    Aug 2014
    CHICAGO
    I Wiil TRY Thankyou
    Aug 2014
    CHICAGO
    I changed the programm!
    It compiles fine my
    U2 programmer is working.
    It compiles and programms fine in Micro Code Studio Plus
    however no red light is flashing on the U2 programmer .
    PS: my U2 programmer is working.
    When I check the HEX. File in meProg.
    After programming the HEX. File looks different !
    '* Name : TEST_0_16F88_config_3 *
    '* Author : [WVA] *
    '* Notice : Copyright (WVA) 2014 *
    '* : All Rights Reserved *
    '* Date : May/ 2015 *
    '* Version : 1.0 *
    '* Notes : INITIAL_SETUP_16F88 *
    ;----[16F88 Hardware Configuration]---------------------------------------------
    #IF __PROCESSOR__ = "16F88"
    #DEFINE MCU_FOUND 1
    cfg1 = _INTRC_IO ; INTRC oscillator; CLKO function on RA6/OSC2/CLKO pin and port I/O function on RA7/OSC1/CLKI pin
    cfg1&= _WDT_OFF ; WDT enabled
    cfg1&= _PWRTE_OFF ; PWRT disabled
    cfg1&= _MCLR_ON ; RA5/MCLR/VPP pin function is MCLR
    cfg1&= _BODEN_ON ; BOR enabled
    cfg1&= _LVP_OFF ; RB3 is digital I/O, HV on MCLR must be used for programming
    cfg1&= _CPD_OFF ; Code protection off
    cfg1&= _WRT_PROTECT_OFF ; Write protection off
    cfg1&= _DEBUG_OFF ; In-Circuit Debugger disabled, RB6 and RB7 are general purpose I/O pins
    cfg1&= _CCP1_RB0 ; CCP1 function on RB0
    cfg1&= _CP_OFF ; Code protection off
    __CONFIG _CONFIG1, cfg1
    cfg2 = _FCMEN_ON ; Fail-Safe Clock Monitor enabled
    cfg2&= _IESO_ON ; Internal External Switchover mode enabled
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]---
    ; Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
    #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    define OSC 4
    OSCCON=%01100000
    cmcon = 7 'comparator off
    ADCON1 = 7 'analog digital of
    ANSEL=0 'set i/o to digital
    TRISA=%11111111 'all A ports inputs
    'PORTB=%00000000 'Initiate all port B pins to 'low
    TRISB=%1100000 ' all ports outputs
    PORTB.0=0 'LED of
    'PORTB.1=1
    pause 1000 'Delay 1/2 second
    PORTB.0=1 'LED on
    'PORTB.1=0
    PAUSE 1000 'Delay 1/2 second
    goto main 'Loop back and do it again
    How is the programmer connected?
    To avoid problems in the future:
    http://www.picbasic.co.uk/forum/show...556#post127556
    Also, use uppercase for DEFINEs.
    Your config looks wonky.
    This looks like left-over from a copy&paste.
    Aug 2014
    CHICAGO
    Thanks, i dd
    if you load your (programmed as discussed) 16f88 into the u2 then use the "read" icon do you get results as per this attachment ?
    can you erase a chip ?
    can you verify a blank chip ?
    can you reprogram chip and then verify it ?
  1. 16f688 interrupt
    By RHS_electronics in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 19:27
  2. PC to EUART on pic 16F688
    By docaberle in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 07:33
  3. 16f688 Adc
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2008, 11:34
  4. 16f688 <-> Max232
    By PlantBob in forum Serial
    Last Post: - 25th March 2008, 15:57
  5. Help with 16f688
    Last Post: - 21st October 2006, 00:12
