Pic Basic has a analogue to digital converter
Results 1 to 6 of 6
    Jun 2015
    Default Pic Basic has a analogue to digital converter
    Is it possible to use a Pic Basic has a analogue to digital converter or has a interface.
    For example reading a voltage from 0 to 5 volts so it can be converted into digital by the Pic Basic and fed into the USB of a computer.
    Thanks heaps.
    Oct 2009
    Utah, USA
    Default Re: Pic Basic has a analogue to digital converter
    Yes, a PIC and PICbasic can easily do that.
    Have you worked with PIC's before?
    Have you tried the usual "blink an LED" for starters to learn pic's??
    Dwight
    Jun 2015
    Yes I have used a Pic before, only the basics.
    Oct 2009
    Utah, USA
    Do you already have a PIC chip model in mind??
    Are you targeting a specific pin count or just wanting to experiment with A/D?
    As far as feeding the A/D value to a PC via USB, I have not done that (others here have I'm sure) but you could easily write that value to an LCD or other display or feed it to a PC via serial.
    Some more specifics on what your overall goal is might help.
    Dwight
    Jun 2015
    Any Pic chip would do and just any number of pins would be fine.
  1. Replies: 10
    Last Post: - 21st April 2011, 14:19
  2. TDC!! (time to digital converter)
    By ibra in forum mel PIC BASIC Pro
    Last Post: - 20th October 2010, 10:46
  3. Digital to Analog Converter
    By kutsi in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 19:17
  4. Pin as Digital and Analogue
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 16th July 2006, 09:41
  5. AD7391 digital to analog converter
    By srob in forum mel PIC BASIC Pro
    Last Post: - 12th November 2005, 12:07
